Creaking coming from both sides at the rear ?
JEMAN
Morning all :)
As some of you no, I'm trying to resolve a few issues on my 2003 Z. So for the rear axles clicking has been sorted and plugs changed. The issue I'm trying to resolve is this creaking noise coming from both sides at the rear when I go over uneven surfaces like pulling into my driveway. Yesterday I looked at the anti roll bar bushes (kiwi fit said it was them) causing the noise. I loosened the bracket that holds these bushes in place and greased the bar then re fitted the bracket and tightened. Drove the car of the ramps and.........no difference. So obviously it wasn't them. Any ideas as to what is the cause, or if there is a common fix for this. With the hand brake on, if I rock the car back and forth it happens more so than up and down. Money's a bit tight at the mo so trying to resolve rather than use a garage for the time being
Cheers
Thanks so much guys.....I'll try greasing, but will replace when I can...........so they are the small links on the end of the anti roll bar that go up also ? Sorry, but I'm not to sure what to look for.
Cheers
