geeunit199 Posted August 9, 2014 Posted August 9, 2014 my headlights have the halogen main beam and the dip has been changed from the xenon to a halogen, the dipped lights are absolutely rubbish, i might as well have two candles. why would somebody down grade them? one ballast is damaged so i guess cost could have been the answer but i can't understand why u would make them worse, how much are the replacement ballast units? grant Quote
Ekona Posted August 9, 2014 Posted August 9, 2014 Yup, cost. This is what happens when cars drop massively in value, they get picked up by skinflints who don't appreciate that these were nigh-on £30k cars when new. Probably been run on 95 as well, to save a few quid. Quote
StevoD Posted August 9, 2014 Posted August 9, 2014 think i got a cost of just over £200 for one bulb from nissan went to ebay got a pair for £60 Quote
geeunit199 Posted August 10, 2014 Author Posted August 10, 2014 how good are the factory xenon dipped lights on an 03 model? Quote
spursmaddave Posted August 10, 2014 Posted August 10, 2014 how good are the factory xenon dipped lights on an 03 model? Rubbish Quote
ZMANALEX Posted August 10, 2014 Posted August 10, 2014 As others have said, simply cost. Fully working pre-owned ballasts are in stock if required. Just drop me a PM if I can help further. Alex. Quote
KyleR Posted August 10, 2014 Posted August 10, 2014 Ballast should run about £60 on eBay and a pair of matching bulbs about £20 Quote
geeunit199 Posted August 17, 2014 Author Posted August 17, 2014 what i will do then is buy a pair of bulbs off ebay and use the intact side to test, if that works il but a lead for the other side and go from there. thanks guys Quote
geeunit199 Posted August 18, 2014 Author Posted August 18, 2014 As others have said, simply cost. Fully working pre-owned ballasts are in stock if required. Just drop me a PM if I can help further. Alex. how much would a ballast be zmanalex? Quote
