Rachel1983 Posted August 8, 2014 Share Posted August 8, 2014 Hi, I've got my new mid pipe and low mileage back box. Do I need some kind of mounting kit? If so what am I looking for and where? Also is there anything I need to go between the flange of the mid pipe and flange of the back box? Or do they simply just click together?? Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 8, 2014 Share Posted August 8, 2014 Depending on the system and model of car you should be able to reuse the existing brackets and mounts. You will require NEW gaskets and a hardware kit for the joints. Alex. Quote Link to comment Share on other sites More sharing options...
andybp Posted August 8, 2014 Share Posted August 8, 2014 unless the nuts and bolts are stainless they will probably be a bit worse for wear and not really worth trying to re-use old gaskets if you're doing it yourself use penetrating oil before trying to undo old fixings i'm sure Alex can supply all you need Quote Link to comment Share on other sites More sharing options...
Rachel1983 Posted August 8, 2014 Author Share Posted August 8, 2014 Thank you both for your help. Alex, can you give me a price for what I'll need please Quote Link to comment Share on other sites More sharing options...
