Space Saver wheel
GT Driver
Got a puncture on the front last Saturday. The space saver wheel wouldn't fit over the Brembo caliper on the front, which was to be expected. However, I put the spacer saver on the rear, which fits fine, but couldn't get the rear Rays wheel to fit on the front to replace the punctured tyre.
From talking to micknero on here he said to unscrew that small bolt on the brake disc hub surface and it the rear Rays wheel should fit fine on the front, but do any of you have issue with rubbing off the wishbone control arm? I know the wheel is wider than the fronts as is the tyre width. Would just like to know next time instead of having to call the AA!
Why don't you try it and find out for your self ?
That way you will know for sure, however I doubt if you will have any fitment issues, providing you have the correct wheels and tyres.
Alex. :)
Edited by ZMANALEX
