IT10 Posted August 28, 2007 Share Posted August 28, 2007 Hi all I had the airbag warning light start to flash on my Z yesterday. I had a search but couldn't find anything, is this a common issue? Im a bit miffed as the car is 6 weeks out of warranty and no doubt it will be expensive Quote Link to comment Share on other sites More sharing options...
James350z Posted August 28, 2007 Share Posted August 28, 2007 Mine started flashing last month. Tried resetting it. All fine for about 5 miles then flashing started again. Got Nissan to take a look. Appartely its a common fault with the connectors under passanger seat. They fixed it in about an hour and its been fine since. Didnt cost me anything cos its still under warranty but cant see it costing too much. Quote Link to comment Share on other sites More sharing options...
IT10 Posted August 28, 2007 Author Share Posted August 28, 2007 Cheers for the info James - idiots question here; how do you reset it?? I may have missed that part in the manual. Cheers Quote Link to comment Share on other sites More sharing options...
James350z Posted August 28, 2007 Share Posted August 28, 2007 1. Turn ignition switch from OFF to ON. 2. Air Bag warning lamp is on for 7 seconds and turns off, then turn ignition switch OFF within 1 second after the lamp turn off. 3. After ignition switch is turned OFF, wait for more than 3 seconds. 4. Repeat steps 1 to 3 twice. (Perform 3 times in total.) 5. Turn Ignition switch ON. 6. The SRS lamp has been reset it. Hope this helps Quote Link to comment Share on other sites More sharing options...
IT10 Posted August 28, 2007 Author Share Posted August 28, 2007 You're a star, thanks James Off to the carpark now to try! Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 28, 2007 Share Posted August 28, 2007 You're a star, thanks James Off to the carpark now to try! How did you get on? Quote Link to comment Share on other sites More sharing options...
IT10 Posted August 28, 2007 Author Share Posted August 28, 2007 Well I reset it, and then turned the ignition back to ON. Light started flashing within 5 secs so James' 5 miles was quite good! Looks like a trip to the dealer is on the cards for me EDIT - Tried again and it stayed out for the half hour drive home from a mates, so fingers crossed! Quote Link to comment Share on other sites More sharing options...
James350z Posted August 29, 2007 Share Posted August 29, 2007 I would get it checked out at a dealer mate. apparently when the light is flashing all airbags are deactivated! That might just be rumors tho! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 29, 2007 Share Posted August 29, 2007 Hi all I had the airbag warning light start to flash on my Z yesterday. I had a search but couldn't find anything, is this a common issue? Im a bit miffed as the car is 6 weeks out of warranty and no doubt it will be expensive you didn't search very well. Check out the guides section. Obvious http://www.350z-uk.com/forum/viewtopic.php?t=3279 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 29, 2007 Share Posted August 29, 2007 I would get it checked out at a dealer mate. apparently when the light is flashing all airbags are deactivated! That might just be rumors tho! might be worth checking the fuses Quote Link to comment Share on other sites More sharing options...
NWZ Posted September 5, 2007 Share Posted September 5, 2007 Mine had the flashing airbag light. Took it into dealer yesterday and they said it was a side airbag module that was at fault and they have ordered a new part. They also reset the light so it no longer flashes. I did ask them when the light is flashing are the airbags deactivated and their response was a firm YES. Seems a bit dangerous, why couldn't Nissan program the other airbags to remain active when this happens! Quote Link to comment Share on other sites More sharing options...
GC350z Posted September 5, 2007 Share Posted September 5, 2007 I would of thought because the air bags all work together to protect you. Could be wrong. Quote Link to comment Share on other sites More sharing options...
