Penetrating Fluid for Exhaust Job
badCOK
Hi guys,
going to be fitting my Ark Exhaust in the next week or so.
Looking to spray the bolts the day before to make the job slightly easier.
What Penetrating Sprays have people used? or recommend?
Paul
If they have not been undone before I would get it on a ramp or bung a garage £20 to loosen everything you need, then go home and change the exhaust yourself, after almost blow torching my face off I would suggest that :lol:
Edited by jumping350
WD40 isnt a penetrating fluid.
Halfords have stopped selling Plus Gas, so i recently just used their off the shelf 3 in 1 penetrating spray. Sprayed on and on the same day the nuts wouldnt move, but seven days later they came straight off.
With the Zed exhaust though you might be lucky to remove some of the bolts without cutting them out with a torch. :blackeye:
WD40 do have a penetrating product that is specifically for busting tight nuts :wacko:
Don't know how good it is though,
http://www.halfords.com/motoring/engine-oils-fluids/lubricating-penetrating-oil/wd-40-specialist-fast-release-penetrant-250ml
the OP has actually asked a question that i had in mind to put forward at sometime so would be interesting to see if anyone has used this particular product..
  • 1 month later...
