Differences between vortech V2 & V3 superchargers & best place to buy?
Kerry
Hi I wondered if anyone could tell me the differences between the vortech V2 & V3 superchargers?
I also wondered where is the best place to purchase a charger from and is there or will there be any group buys going on in the near future?
The oil feed is the main difference but you also need to decide what Trim as this is also very important and determines the type of bearings, gear set, max rpm, impeller efficiency and ultimately power output.
For the 350z these sc that will fit the std brackets
V2 SC (discontinued): std bearing 52krpm
V3 SCi = V2 SCi = std bearing 53krpm/improved cast impellers rom sc
V2 Si = std bearing 53rpm/more efficient cast impeller
V2 T = HD bearing 55krpm/cast impeller
V1 T = HD bearing but bigger straight cut gears so stronger but noisier than the V2 >V3
V2 Ti (new) = HD bearing 55rpm/ more efficient billet impeller
V1 Ti : as above
V7 YSi = HD race bearing 65krpm/ cast impeller
V7 YSi (new)= HD race bearing 65krpm/ billet impeller
Personally I favour the V2 as it offers superior cooling but others prefer the simplicity of the self lubricated V3. But if you factor in the recommended sc oil changes it's not so simple or cheap.
I have the V2 T trim which I've just sold for the new V7 YSi.
V1 Ti : as above
:thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
i have a V3
V1 Ti : as above
Ok ok... Calm down :lol:;)
Kerry you have just missed a "group buy" on the Vortech V3 sci kit I'm afraid. Doubtful there will be another one for quite sometime but you never know.
I'd speak to Chris at Tarmac Sportz as that's where I and quite a few other members got their superchargers from. :thumbs:
  • 2 years later...
Has the higher operating temperature of the V3 been an reported as an issue for anyone? The changing of the oil for the SC does sound like a hassle, although as my engine is currently burning oil perhaps it would be a better option for 2006 models!
