spursmaddave Posted August 3, 2014 Share Posted August 3, 2014 What length wheel studs did you use. ?. The spacers bolt to the standard studs on the hub then the wheels bolt to the spacers Yep he's got it 👠I had them on my Zed One top tip - Put some copper grease on the spacer bolts and do NOT over torque them! As the spacers are soft you can end up forcing the bolts into the spacer and you will not get them out without cutting the bolts off mosg likely... Quote Link to comment Share on other sites More sharing options...
Zhorno Posted August 3, 2014 Author Share Posted August 3, 2014 What length wheel studs did you use. ?. The spacers bolt to the standard studs on the hub then the wheels bolt to the spacers Yep he's got it 👠I had them on my Zed One top tip - Put some copper grease on the spacer bolts and do NOT over torque them! As the spacers are soft you can end up forcing the bolts into the spacer and you will not get them out without cutting the bolts off mosg likely... Erm bit late lmao Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 3, 2014 Share Posted August 3, 2014 What length wheel studs did you use. ?. The spacers bolt to the standard studs on the hub then the wheels bolt to the spacers Yep he's got it 👠I had them on my Zed One top tip - Put some copper grease on the spacer bolts and do NOT over torque them! As the spacers are soft you can end up forcing the bolts into the spacer and you will not get them out without cutting the bolts off mosg likely... Erm bit late lmao I found out the hard way, well Darren did as he was fitting some discs & pads for me they must have been put on with a windy gun and we got them all off bar one which did eventually come off but got mangled... Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted August 3, 2014 Share Posted August 3, 2014 Is there a torque figure for them..? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 3, 2014 Share Posted August 3, 2014 Is there a torque figure for them..? I knew someone would ask Afraid I don't know but I am sure someone more knowledgable will Will 1 Quote Link to comment Share on other sites More sharing options...
martybhoy Posted August 5, 2014 Share Posted August 5, 2014 Stunning car, very similar for what I have in mind for mine. 1 Quote Link to comment Share on other sites More sharing options...
