dannybz Posted July 28, 2014 Posted July 28, 2014 (edited) Hi guys, I am going to do and oil and filter change, but need to know after the oil has been completely drained from the 350z 2004 how much do i put back in? I cant really trust using the dipstick so just need to know the right amount to put in... i assume some of you guys will know Edited July 28, 2014 by dannybz Quote
ZMANALEX Posted July 28, 2014 Posted July 28, 2014 Circa 5 litres if you are also swopping out the filter, however from cold with fresh oil it is easy to get a true reading from the dip stick. Alex. 1 Quote
ATTAK Z Posted July 28, 2014 Posted July 28, 2014 Not wishing to contradict Alex but I thought it was 4.7 l 1 Quote
ZMANALEX Posted July 28, 2014 Posted July 28, 2014 Not wishing to contradict Alex but I thought it was 4.7 l Circa :lol: Quote
dannybz Posted July 28, 2014 Author Posted July 28, 2014 Both right Engine oil - with filter change 4.9 litres - without filter change 4.6 litres - dry engine overhaul 5.5 Quote
BulletMagnet Posted July 28, 2014 Posted July 28, 2014 But honestly, who does an oil change without oil filter change? Quote
ATTAK Z Posted July 28, 2014 Posted July 28, 2014 Both right Engine oil - with filter change 4.9 litres - without filter change 4.6 litres - dry engine overhaul 5.5 Where did you get these figures from ? 1 Quote
dannybz Posted July 28, 2014 Author Posted July 28, 2014 Think it is from the manual... found it in a post after looking. 1 Quote
Z_Lover Posted August 3, 2014 Posted August 3, 2014 I changed oil and filter and refilled 4,7 liters,..........additional info. between the min and max signs at the oil level gauge is roundabout 1,6 litres and not as usual at "normal" cars 1litre. keep caution,.....i tested it because some folks in the german forum told me it is 1 litre and i refuelled 1litre at the min. gauge and there was a leak to the maximum. Rgds Michael Quote
