nissanjuke Posted July 25, 2014 Share Posted July 25, 2014 light came on.have checked everything,nothing seems wrong,does anybody have any tips to get this light off,only last week ,airbag lights came on,but was able to fix it,thanks to the lads at the forum. my car is a 2005 350z. any tips Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 25, 2014 Share Posted July 25, 2014 Do the pedal dance to read the code and then clear it. Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 25, 2014 Author Share Posted July 25, 2014 whats that I am a newbie to the z clan Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 25, 2014 Share Posted July 25, 2014 http://www.350z-uk.com/topic/53148-how-to-ecu-accelerator-pedal-throttle-valve-resets/ Let us know how you get on... Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 25, 2014 Author Share Posted July 25, 2014 pedal dance didn't work,tried disconnecting positive from battery-no work,tried 10 mins disconnection of negative -no work any other idea ????? Quote Link to comment Share on other sites More sharing options...
Floydbax Posted July 25, 2014 Share Posted July 25, 2014 Could be the hairspring in the steering wheel, that was my problem. Something to bear in mind if you have checked everything else - the old Sherlock Holmes thing, once you have eliminated the obvious etc...... (It can be an intermittent problem if it is broken but it does need fixing - it's not too difficult). Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 25, 2014 Share Posted July 25, 2014 Buy a code reader or see if anyone has one to you locally that you could borrow. The pedal dance will work but it does take some skill and a few trys, hence why I ended up buying a code reader... Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 25, 2014 Author Share Posted July 25, 2014 I will check if any body has a code reader,where is it plugged in on the 350z Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 25, 2014 Author Share Posted July 25, 2014 how long would you have to disconnect your positive on your battery for it to go away. Quote Link to comment Share on other sites More sharing options...
Floydbax Posted July 25, 2014 Share Posted July 25, 2014 The port for the reader is located by your right knee Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 25, 2014 Share Posted July 25, 2014 (edited) http://www.eBay.co.uk/itm/321360042220 Edited July 25, 2014 by Gudzy Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 25, 2014 Author Share Posted July 25, 2014 thanks guys for all your help Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted July 26, 2014 Share Posted July 26, 2014 If you use your phone to record when you do the pedal dance you can play it back and count the flashes of the lights which will give you the fault code. Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 26, 2014 Author Share Posted July 26, 2014 just bought a code reader £10.00 off ebay. I will use it anyway and at £10.00 well cheap. easer than doing the pedal dance. thanks guys Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 26, 2014 Share Posted July 26, 2014 Pedal dance is easy if you use your phone as a stopwatch and then record the code 1 Quote Link to comment Share on other sites More sharing options...
nissanjuke Posted July 31, 2014 Author Share Posted July 31, 2014 thank GUDZY code reader well worh it. for £10 does it in seconds. my problem was my miltek exhaust,nothing serious!!! :teeth: Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 31, 2014 Share Posted July 31, 2014 (edited) Saves you knowing which pedal is which when you can just plug something in... Edited July 31, 2014 by Gudzy Quote Link to comment Share on other sites More sharing options...
