New HU install = Quiet rear speakers?
newswseller
So i installed a new headunit (with a PAC-OEM etc..), after some fiddling around I noticed that the rear speakers are really quiet.
The fronts are perfect, say i have it on vol level 15, if i fade to rear then i have to up it to say 30 to get a decent sound..
I've checked and re-checked all the wiring, nothing loose and everything is connected up correctly. Any Ideas?
Have you tried fiddling with the adjusters on teh PAC-ROEM unit? There is a potometer (sp?) for each channel that you can adjust how loud they are.
I was wondering what those holes in the PAC-ROEM unit did, can't believe what a tard i am.. No doubt this will solve the prob :thumbs:
Think I turned mine all the way up and then back down a little, with the same for each one and they seemed balanced as the OEM setup. Just remember to turn the front and back pairs with each other (ie RR + RL the same) so you dont get a miss balance.
Just need to have a play and you should be able to solve it :thumbs:
