Decats
Yellowgt4
Hi guys I just fitted cobra decats non silenced. And since this I am getting strong smell of exhaust fumes in the cabin. Also when in idle under hard acceleration there a grey/blueish smoke coming from the tailpipes. The smell is really bad. I have a video but don't know how to add it. I'm concerned that I may be doing damage to my car! There is a leak in my y pipe which is drawing in air and making a really loud noise too. Any help would be appreciated!
Cheers
Steven
  • 2 months later...
My exhaust is blowing a little since fitting decats too, will it cause any damage? Got me worried now :surrender:
i kind of get a hissing noise when I lift off.
Can't see it causing damage, unless there is a massive hole and a stone gets sucked up into the engine :lol:
Just need to source where it's blowing from.
Cheers
Steven
U alright mate u are not alone I have the exact same as you. Same brand, my Y pipe is blowing too lol. That smell is disgusting it actually makes me feel sick. The only thing I don't get it the blue smoke. I'm gonna invest in a new Y pipe soon and see if that sorts it at least a bit.
That's what she 'Zed' :-/
If the leak is before the first lambda sensor which means it would have to be in the manifold and you would indubitably hear it, and it would affect the running, if the lambda sensor is seeing extra air from a leak it will increase fueling to compensate,
otherwise if the leak is elsewhere downstream of the sensor it shouldn't cause a problem.
