leebottrill Posted July 20, 2014 Share Posted July 20, 2014 Hey. I can't seem to get the window and mirror switch panel off. Its the wiring unit that doesn't seem to come out. Isthere a technique that allows the wires to come out easily i don't want to force it in case i break the window. Quote Link to comment Share on other sites More sharing options...
Mike_89 Posted July 20, 2014 Share Posted July 20, 2014 (edited) Unscrew the panel. There is a screw in the handle. Once you have this out give the panel a gentle pull upwards and it should come out. Sorry I have just digested your post. It sounds that you have already got that far. If you use a thin flat-blade screwdriver on the clips around the switch units, it should come free nicely. On the plug connector there is a press point, if you press this in and pull the plug, it should come free. Edited July 20, 2014 by Mike_89 Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted July 21, 2014 Share Posted July 21, 2014 The above should help sort out the problem for you. Quote Link to comment Share on other sites More sharing options...
