Justthejedi Posted July 18, 2014 Share Posted July 18, 2014 Hi all I have a problem with wheel vibration from 75mph+ after fitting new aftermarket 18" alloys. I ordered a set of spigot rings, size 74.1-66.6, 3x fit fine, the problem is the o/s/f hub, when fitting the ring there is very slight play, and I mean very slight play but it seems enough to make the wheel vibrate @ 75mph+. It fits into the wheel fine, nice and tight. I had a replacement ring sent, tried that, exactly the same problem, just very slight play when fitted over the hub. I have found out the hub size on 350's is 66.1 but cannot find this size anywhere to buy, nobody seems to do them so they send 66.6 instead. I have had all wheels balanced so can't be that. Any help/advise would be really appreciated as I'm at a bit of a loss. Cheers Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 18, 2014 Share Posted July 18, 2014 just out of interest, have you put your original wheels back on to see if you still have the problem Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 18, 2014 Author Share Posted July 18, 2014 just out of interest, have you put your original wheels back on to see if you still have the problem No Mike, as I swapped the tyres from my original touring wheels onto my new wheels. Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 18, 2014 Share Posted July 18, 2014 so 2 rings of the same size dont fit on your hub and there the size your hubs meant to be? sounds like your hubs worn away which seems very odd in itself have you fitted the one that dont fit on the opposite wheel to see if the issue moves? Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 18, 2014 Author Share Posted July 18, 2014 I haven't got the facilities to change them myself, I took the car to a Formula 1 centre and they were really good lads to be fair. They said x3 of the rings fitted nice and tight but when fitting the ring onto the o/s/f originally there was slight play on the hub and in the wheel which caused vibration @ 50mph+, I had a replacement ring sent, this one fitted nice and tight into the wheel (the tyre guy showed me) but when put on the hub, still very slight play. I think I'll go back and ask them to swap the front wheels around. Then take it for a drive. Didn't have this issue when the original wheels were on. Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 18, 2014 Share Posted July 18, 2014 I haven't got the facilities to change them myself, I took the car to a Formula 1 centre and they were really good lads to be fair. They said x3 of the rings fitted nice and tight but when fitting the ring onto the o/s/f originally there was slight play on the hub and in the wheel which caused vibration @ 50mph+, I had a replacement ring sent, this one fitted nice and tight into the wheel (the tyre guy showed me) but when put on the hub, still very slight play. I think I'll go back and ask them to swap the front wheels around. Then take it for a drive. Didn't have this issue when the original wheels were on. make sure the swap spigot rings and make sure you havent got directional tyres of they cant swap them side to side Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 18, 2014 Author Share Posted July 18, 2014 I will, thanks chaps........to be continued....with better news I hope! Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 28, 2014 Author Share Posted July 28, 2014 Well the saga continues.....had the correct size spigot rings made from a company called spigotrings.com. (74.1 - 66.1) had the front wheels rebalanced just to be safe and I still have wheel vibration @ 70+mph? So will take it Back to the tyre place on Wednesday to have the rears re-balanced and if that doesn't cure it I'm completely stumped. Has anybody else had this problem??? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2014 Share Posted July 28, 2014 What exactly is your problem as you now appear to be leaning towards the rear ? Alex. Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 28, 2014 Share Posted July 28, 2014 not got a bent shaft have ya Quote Link to comment Share on other sites More sharing options...
Gudzy Posted July 28, 2014 Share Posted July 28, 2014 (edited) not got a bent shaft have ya That's a bit personal... Have you had an alignment done recently? Edited July 28, 2014 by Gudzy 1 Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 28, 2014 Author Share Posted July 28, 2014 Had no problems running on original touring wheels, car drove fine, fitted new wheels and now have a wheel vibration @70mph+ I can feel it through the steering wheel and see it from the gear stock vibrating. The wife thinks I'm being paranoid but I'm not, it defo isn't right. The spigot rings are a perfect tight fit, front wheels balanced spot on so I'm hoping the rears now need re-balancing and will cure it? if it isn't then I'm completely baffled. Quote Link to comment Share on other sites More sharing options...
Daveyboy11 Posted July 28, 2014 Share Posted July 28, 2014 One of the wheels isn't buckled is it? Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 28, 2014 Author Share Posted July 28, 2014 I don't think it can be a buckled wheel as the tyre place would have picked it up when balancing them? Plus it would vibrate at all speeds not just from 70mph. I haven't changed to a bigger size either, stuck with 18's. Quote Link to comment Share on other sites More sharing options...
Daveyboy11 Posted July 28, 2014 Share Posted July 28, 2014 Possibly a very slight buckle? The tyre place should pick it up though you're right, I had a buckled wheel and it was so slight it didn't cause any vibration until about 60mph. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 28, 2014 Author Share Posted July 28, 2014 This is a real mystery, I have never had problems like this before. I have heard of people changing to a bigger wheel and it exposing problems previously hidden by original wheels but I've stuck to the same size. The tyre place had to put a tube in one of the rears to get it to inflate as they had problems in stretching the tyre over the rim (9.5). could this be the problem? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2014 Share Posted July 28, 2014 If you are getting vibes through the steering wheel then it has got to be fronts. Going with the information that you have provided, guess that you have a buckled wheel or the wheel is not mating with the hub. Alex. 1 Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 28, 2014 Author Share Posted July 28, 2014 I'll get the wheels checked again.......to be continued! Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 30, 2014 Author Share Posted July 30, 2014 Took the car to a new tyre place and they found that all x4 wheels had not been balanced correctly by the previous tyre place, 25g out on the front, 55g on the rears! This has helped but there is still a vibration @ 75mph+. It's not as bad as it was but it's still there bugging me! I've now been told it could be my rear tyres as they are stretched to the limit to fit over the 9.5 rim and they are distorting. One of them has a tube in it so they could inflate it. Could this be causing the wheel wobble? Quote Link to comment Share on other sites More sharing options...
a2orry Posted July 31, 2014 Share Posted July 31, 2014 A TUBE thats not on mate tyre fitter should have told you that you need a new tyre or wheel .l would never fit a tube. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted July 31, 2014 Author Share Posted July 31, 2014 I'm thinking the tube could be the problem too. From the feedback I have had from other members, they had no issues in fitting the standard rear tyres over a 9.5 rim. It took Formula 1 autocentre an hour to inflate one wheel, they couldn't even inflate the other so ordered a tube so they could stretch the tyre over the rim and to cap it all, they're equipment is out of calibration. Quote Link to comment Share on other sites More sharing options...
