Snapped gear stick
Vlad
Got short shifter fitted and it tiny little bit miss-aligned...all heard ok, reverse goes in tight...
Was driving earlier and went to put in reverse... And this happened
Actual gear stick is snapped...was a right mission to drive it home lol
Happened to anyone before?
The actual stick itself was pretty warm...so I think it heated up and gone softer and that's why it snapped with a bit of force (minimal force)
Is it normal for them to get warm? Obv whole tunnel gets pretty warm and heat travels...but never noticed it before as never driven around changing gear using bottom of the stick lol
Looks like OEM gear stick thing goes back in tomorrow
Just need to drill out snappd bit from the gear knob lol
Maybe because that knob is frickin enormous, the extra length acted as a lever and increased the pressure at the pivot point causing it to snap?
That would be my guess too. ;)
What short shifter was it Vlad?
Wasn't some eBay "china made" special or something was it?! :surrender::dry::lol:
Had my B&M shifter snap in exactly the same circumstances. I had the Tegiwa extension on it. I agree it's the lever arm that's fatigued the metal at the weak spot which if the transition between the geartsick and knob extension.
I plan to weld a thick sleeve around it as I miss my short shifter.
