Rock_Steady Posted July 16, 2014 Share Posted July 16, 2014 So, I decided to drive the zed to work and 2 things happened. 1: My fish salad leaked onto the passenger seat 2: whilst in traffic I noticed that the temp needle was just over half way, I kept my eye on it and it started to get a little higher. The fans weren't kicking in!! I made this face so, I turned on the heaters to full blast and turned off the car when it was @ a stand still. it never got near the red but hopefully there is no damage. No steam, no coolant leaking out anywhere. Should I be worried? 1 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted July 16, 2014 Share Posted July 16, 2014 Run it while standing still and check it fans are cutting in, ?. 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 16, 2014 Share Posted July 16, 2014 (edited) I would check your coolant level from cold and also check the fans are kicking in when sitting stationery. edit: you are to fast for me Will. Alex. Edited July 16, 2014 by ZMANALEX 2 Quote Link to comment Share on other sites More sharing options...
rjohnson1993 Posted July 16, 2014 Share Posted July 16, 2014 Check both fans are working, same happened with mine, turn air-con on to check this. 1 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted July 16, 2014 Author Share Posted July 16, 2014 will do guys, just bought some coolant so i'll have a butchers. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted July 16, 2014 Share Posted July 16, 2014 Don't suppose you got a Nismo Radiator cap... :scare: Quote Link to comment Share on other sites More sharing options...
StevoD Posted July 16, 2014 Share Posted July 16, 2014 none wants a fishy damp passenger seat 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted July 16, 2014 Share Posted July 16, 2014 none wants a fishy damp passenger seat I dunno? ...depends how it got like that. ;) 1 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 16, 2014 Share Posted July 16, 2014 fan motors probably failed. Its a common fault. Mishimoto do a replacement kit which is loads cheaper than getting new motors from Nissan. Clark Motorsport supply the Mishimoto Radiator Surround Kit which includes the fans. Looks nice too 2 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted July 17, 2014 Author Share Posted July 17, 2014 well, there was still plenty of coolant, it was right up to the top. The drive home was fine, it never over heated. So, next step is bumper off and check out the rad fans and electrics. And while i'm at it I think i'll re-spray the bumper and repair it as I hit uneven ground on the same day and cracked the fibre-glass Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 17, 2014 Share Posted July 17, 2014 You do not require the bumper off to check or remove the rad. fans. 2 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted July 17, 2014 Author Share Posted July 17, 2014 You do not require the bumper off to check or remove the rad. fans. Aha!! thanks for this!! live and learn. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted July 17, 2014 Share Posted July 17, 2014 (edited) Just run the car on tickover until the fans cut in or don't cut in, and keep an eye on the temp gauge, you will hear when they start, as Alex said you don't need to take off the front bumper.. Edited July 17, 2014 by WhackyWill 1 Quote Link to comment Share on other sites More sharing options...
