Davewagon Posted July 15, 2014 Share Posted July 15, 2014 Hi all, Could someone please tell me the nissan part number for rear toe adjuster bolts. Every search I've done inevitably leads to Eibachs or other third party stuff specifically for lowered cars... I just need standard Nissan oem part number to give to the parts desk - I rang them earlier and they seem to think I'm talking about part number 55424 in the below diagram (but is willing to be proven wrong)- is that correct? Many thanks, David 350z rear suspension.pdf Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 15, 2014 Share Posted July 15, 2014 One of these, one is toe and the other is camber, I can never remember which is which. 55226 8J000 55226 AL500 1 Quote Link to comment Share on other sites More sharing options...
Davewagon Posted July 16, 2014 Author Share Posted July 16, 2014 Brilliant Alex thank you! So from the diagram the parts chap gave me, that'll be either 55226P or 55226PA? Many thanks, David Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 16, 2014 Share Posted July 16, 2014 Brilliant Alex thank you! So from the diagram the parts chap gave me, that'll be either 55226P or 55226PA? Many thanks, David That is correct David. Alex. 1 Quote Link to comment Share on other sites More sharing options...
Davewagon Posted July 16, 2014 Author Share Posted July 16, 2014 Are they the same bolt then? Or slightly different shape/design? As I'll just get the cheaper one if they are the same - something tells me I doubt they are the same though? David Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 16, 2014 Share Posted July 16, 2014 The only difference is that one is 2mm longer than the other so if in doubt go with the longer of the two. Quote Link to comment Share on other sites More sharing options...
Davewagon Posted July 16, 2014 Author Share Posted July 16, 2014 Thanks Alex! For reference (if anybody else needs this information): 55226P - Toe bolt - £14.44 55226PA - Camber bolt - £11.02 If required washer - £8.30 (WTF?!) Nut - £2.57 Cheers, Dave Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 16, 2014 Share Posted July 16, 2014 The washer is disc-eccentric, and is what makes the adjustment possible so £8.00 each is a fair price. I have all this stuff in stock (pre-owned) so you will know for the next time. Alex. 1 Quote Link to comment Share on other sites More sharing options...
