BLEEDING clutch line! Wee tip.
wideboy
Not sure if this has been mentioned before but after spending far too long bleeding the bleeding clutch line, a quick tip:
If you're having issues building pressure, but are seeing few/if any air bubbles coming out when bleeding using the standard method (5 pumps of clutch, hold pedal down/open/close/leave 5 sec/repeat) then try manually pressing the slave fully in whilst opening the bleed screw briefly. Worth doing a couple of times.
I've bled this line a few times now, the standard method has worked fine every other time, but this time I had the entire system dry after changing a few lines and it just refused to build any pressure at all.
Was ready to give up and go buy a power bleeder! A few times bleeding while depressing slave and an instant response! I'd go for a few more rounds of the standard bleed after you've done this to ensure no air has gone back into the flex line.
Have fun :)
