pictures not moving across
nissanjuke
I know we've been down this path before
http://www.350z-uk.com/topic/87482-pictures-not-moving-across/
but are you just trying to add a photo into the body of your text - As per GIXXERUK above.? Or is there some other scheme afoot?
If that's all it is, all you need to do is paste the copied link (make sure you have all the text selected) from the IMG field it into the space you want the photo to appear in your text.
Like
This
Edited by SuperStu
click on image on your reply box and a box comes up
click on img it copies photobucket
paste it into small box
press ok
nohing happens
but t will paste file into topic box/smaller box but nothing happens :surrender::wacko: :wacko: :scare:
There's no boxes, just this white space where you put your text and your IMG code from photobucket. It will look like this below when you have pasted it into the correct place the IMG code is in red
If this is a wind up, it's easily the best ever and I salute you.
Having looked at your other thread, you posted the direct links which is why they didn't show up correctly.
You need to copy and paste the tag.
It is the bottom of the 4 links that photobucket gives you the option for.
