balla Posted July 11, 2014 Share Posted July 11, 2014 Right my car is booked in for mot tomorrow at 12:15 my car has been stood dry for a year, took it to work today to sort a couple bits out and on the way home it overheated I checked the thermostat when I had it off the road and it opened a little bit about 6-7 mm so I think that may be the problem as my top rad hose is really hot and the bottom is cold so I'm getting no flow but could this also be the water pump and if it is where is that located. Also the heaters are blowing cold air but did warm up for a tad when I gave it a little. What do people think and where can I get these parts tomorrow as I need it mot ? Quote Link to comment Share on other sites More sharing options...
Mikeyazure Posted July 11, 2014 Share Posted July 11, 2014 could be an airlock.. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted July 11, 2014 Share Posted July 11, 2014 Where are you located? Might be a member/trader close by Quote Link to comment Share on other sites More sharing options...
balla Posted July 11, 2014 Author Share Posted July 11, 2014 Could well be but I've followed the bleed procedure í ½í¸• And I'm in Northamptonshire I don't mind traveling within reason as I still have use of a car tomorrow but after tomorrow I have to give the car back hence the urgency Quote Link to comment Share on other sites More sharing options...
GMballistic Posted July 11, 2014 Share Posted July 11, 2014 Shouldn't stop you getting your MOT done though should it, ...unless the garage is really far away? Quote Link to comment Share on other sites More sharing options...
balla Posted July 11, 2014 Author Share Posted July 11, 2014 It's not really the problem I need the car working as I will be car less if it's not. Are they commonly stocked by part suppliers ? Quote Link to comment Share on other sites More sharing options...
GMballistic Posted July 11, 2014 Share Posted July 11, 2014 I'd imagine Clark Motorsport will have everything you'll need. Link: http://www.350z-uk.com/forum/207-clark-motorsport/ ...but obviously that won't help you for tomorrow. Best bet would be to ring a local branch of LDS or similar motor factors in the morning if you need them urgently. Can't say for certain whether they'll have them, ..even a Nissan main dealer has to order in most parts. Quote Link to comment Share on other sites More sharing options...
balla Posted July 11, 2014 Author Share Posted July 11, 2014 Ok Thanks if I can't sort it tomorrow I'll give them a call And I was hoping some one might know a common part supplier Also does that sound like a possible fault Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted July 11, 2014 Share Posted July 11, 2014 (edited) I would bleed the system again be sure. Edited July 11, 2014 by Almeida1234 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 12, 2014 Share Posted July 12, 2014 Was this before or after you swopped out the IPDM and the BCM ? If after, I would check that the fan motors are working, in fact I would check out the fan motors irrespective. Alex. 1 Quote Link to comment Share on other sites More sharing options...
jamess115 Posted July 12, 2014 Share Posted July 12, 2014 To solve your problem asap, call Bristol Street Motors riverside. They may see your car today if its urgent and relatively minor. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 14, 2014 Share Posted July 14, 2014 bleeding the system can be tricky and can take a couple of attempts to ensure you have got rid of any airblocks. Also defo worth checking the rad fans as they do fail. Mishmoto do a excellent replacement and cheaper than OEM. Traders here do supply Quote Link to comment Share on other sites More sharing options...
