K370Z2 Posted July 9, 2014 Share Posted July 9, 2014 Hi everyone after just fitting my Eibach lowering springs spacers & Stillen sway bar kit now looking at fitting Front & Rear Camber Arm Kit. Is there anyone out there - Who has done the conversion - What kit did you use - Where did you purchase the kit from? As always all input appreciated. Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted July 10, 2014 Share Posted July 10, 2014 We keep the popular Eibach kits in stock but there are other good options available as well Quote Link to comment Share on other sites More sharing options...
parello9 Posted July 10, 2014 Share Posted July 10, 2014 Eibach is what i run on my coilovers.. Very good setup Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted July 10, 2014 Share Posted July 10, 2014 Its the Eibach that we supplied and fitted to a 370z last month, excellent kit... Quote Link to comment Share on other sites More sharing options...
gstraw Posted July 19, 2014 Share Posted July 19, 2014 have you checked how far our of tolerances you are? I've also got the Eibach and if I need camber kit then i would probably prefer to go for an even bigger drop. i got Eibachs since i was hoping camber kit wouldn't be necessary. Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted July 20, 2014 Share Posted July 20, 2014 Hi mate I fit the se lowing springs and all a needed was a rear adjuster bel camber and toe kit and iv got the camber around +2 all round did not need to play with the front end as the OEM set up adjusted just right Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted July 20, 2014 Share Posted July 20, 2014 Check out my build trend Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
synolimit Posted July 26, 2014 Share Posted July 26, 2014 I'd only run spl! Your life's worth more than saving money on a Chinese item. 1 Quote Link to comment Share on other sites More sharing options...
rob63 Posted August 3, 2014 Share Posted August 3, 2014 (edited) I recently fitted ARK-GTF springs, plus ARB's and drop-links, required camber arms and toe bolts on the rear but the front was fine. All kit supplied through CS, needless to say excellent service as ever. Edited August 3, 2014 by rob63 Quote Link to comment Share on other sites More sharing options...
