dpbayly Posted July 7, 2014 Share Posted July 7, 2014 Well after having my brother-in-law knock me up 2 x 20mm and 2 x 25mm spacers saved a hell of a load of cash as materials cost me £7 each and having them knocked up was free then all I had to do was buy the extended studs which cost £32 so all in £60 bonus, As normal here's a load of pics: New studs fed into place, I had a quick read up to give me a heads up on how to go about fitting them and found it was far easier than others make out in fact the other side rear wheel I didn't even remove the handbrake shoes just simply removed the retaining spring clips and just moved the shoes up and this gave me enough room at the top to feed the new studs into place before drawing them into the flange with a spacer and nut: Here's a front close up comparison one side to the other: Hit a little problem when I got to the last wheel went to crack off the locking wheel nut with a breaker bar the bloody thing broke up and took the key with it as you can see in this picture the locking wheel nut had a weakness you can see it's been rusting so must have been fractured it destroyed the key at the same time: So now had to remove the other 3 locking wheel nuts by smacking a 19mm impact socket down over them: Gave me a good excuse to by a new set of nuts so I have these arriving tomorrow: http://www.ebay.co.u...=item2ed3b65721 Looks great and the wheels sit much better in the arches : Before After Before After Love the look and height it sits especially as it's still sat on standard springs with just the rear spring mount mod done so no need to look at lowering springs: Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted July 7, 2014 Share Posted July 7, 2014 That looks great mate ... Well done Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted July 7, 2014 Share Posted July 7, 2014 Looks mean ....and what a bargain Quote Link to comment Share on other sites More sharing options...
