hyeung Posted June 30, 2014 Share Posted June 30, 2014 Hi, Recently noticed a few black spots of oil leaking under the car. It's situated around the rear centre roughly in line with the wheels and just behind the exhaust box. Having a closer look I took some snaps and there looks to be some black stains running from a hole mounted on a frame...so assume this is source leak? Is this perhap a problem with a rear differential bushing going bad which i assume is mounted in that hole? Can someone knowledgable soul please advise if this sounds about right? If that is the problem, are there known parts available for rectifying this....Also, what's actually involved labour time-wise (hopefully a quick easy fix?) Btw, I'm not sure how long I've had this issue as I only came across it by accident. So rather concerned if there's any associated damage if its been going on for sometime? Any advice would be appreciated. Thanks, Hung Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted July 1, 2014 Share Posted July 1, 2014 Got your PM Hung thought I would post here as well in case anyone else has this issue The rear diff mount bush is oil filled and over time can start to leak. Whiteline sell a replacement bush kit that we stock and sell fro £69. Not and easy 5 minute fit though as a press is required. 1 Quote Link to comment Share on other sites More sharing options...
hyeung Posted July 1, 2014 Author Share Posted July 1, 2014 Quote Link to comment Share on other sites More sharing options...
CJRamze Posted July 1, 2014 Share Posted July 1, 2014 Interesting. Good to keep in mind for the future and very informative Quote Link to comment Share on other sites More sharing options...
