Yella Fella Posted June 29, 2014 Share Posted June 29, 2014 Right, so all I've done is taken out the centre console for a respray as the seller from 2 years ago had a garish chrome flaking finish. My car battery was completely flat as I've accidentally left the onboard camera on and that literally drained it. The LED side sills were disconnected and taped up at the time before the console was removed. Upon charging the battery back up, everything is working fine apart from the following... - Ceiling dome lights dont work, or even when door is open - Indicator lights don't show as on in the dash, no indicator noise (work as normal outside) - Headlamps and side lamps don't show as on as in the dash, no chime if car is off and door is open (work as normal outside) - the mileage counter keeps resetting when ignition is off, as does the clock function in the triple gauge Checked the majority of the fuses in the internal box and nothing has blown. Any ideas before I get charged a wad from Nissan? Quote Link to comment Share on other sites More sharing options...
The Seasider Posted June 29, 2014 Share Posted June 29, 2014 Did you disconnect the battery to charge it? Quote Link to comment Share on other sites More sharing options...
Yella Fella Posted June 29, 2014 Author Share Posted June 29, 2014 Did you disconnect the battery to charge it? Had the car charged up a bit via a mobile tech then I drove it for an hour to charge it up. Ignore the triple gauge one, that's fine actually. Quote Link to comment Share on other sites More sharing options...
The Seasider Posted June 30, 2014 Share Posted June 30, 2014 The reason I was asking about disconnecting the battery prior to charging it was that I believe that if you don't you can cause havoc with the electrics. Same can happen if you jumpstart a car. I recently had a porsche boxster that had a load of electrical components blown out when the guy who was selling it to me jump started it in front of me :-) If I remember correctly, I think there are also some fuses in a box in front of the battery. I haven't got a fuse map handy but it would be worth checking which fuses relate to your problems and recheck them. Quote Link to comment Share on other sites More sharing options...
andybp Posted June 30, 2014 Share Posted June 30, 2014 try fuse no 14 10 amp should be some other things not working if it's this, you might not have noticed though Quote Link to comment Share on other sites More sharing options...
