JEMAN Posted June 28, 2014 Share Posted June 28, 2014 Hi guys, have treated the Z to a new set of spark plugs. It all looks a bit cramped in there to get to the ones on the air pipe side. Is there anything else that needs to come of ? Or anything else you can pre warn me on before changing. Cheers Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 28, 2014 Share Posted June 28, 2014 (edited) It's pretty easy, just a pain in the ass. Remove the strut brace, induction pipe and engine cover and you should be able to get your hands in Edited June 28, 2014 by KyleR 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 28, 2014 Share Posted June 28, 2014 Fiddly but straight forward, allow a couple of hours if first time. Alex. 1 Quote Link to comment Share on other sites More sharing options...
JEMAN Posted June 28, 2014 Author Share Posted June 28, 2014 Thanks guys. I'll give it ago. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 28, 2014 Share Posted June 28, 2014 As above. Not a lot scares me mechanically but there's so much electrical wire in the way that doesn't really flex or move much. Took me 2.5 hrs and gave me sore legs and back for 2 days from bending over the engine 1 Quote Link to comment Share on other sites More sharing options...
Jp606 Posted June 28, 2014 Share Posted June 28, 2014 It's easy, just got remove a few bits first. There are several guides on the internet you can follow. Also you need a thin walled socket to remove/install them. 1 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted June 30, 2014 Share Posted June 30, 2014 There are a couple of guides on the site, as well as something on youtube - the main thing to do - label each coil pack cable thing, as there are a couple which seem to go in the wrong sockets due to the length of them. Easily done - but a photo or two will save you. 1 Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted June 30, 2014 Share Posted June 30, 2014 http://www.350z-uk.com/topic/70229-how-to-change-spark-plugs-part-1-off-side-vq35de/ http://www.350z-uk.com/topic/70230-how-to-change-spark-plugs-part-2-near-side-vq35de/ 1 Quote Link to comment Share on other sites More sharing options...
AndyZ33HR Posted June 30, 2014 Share Posted June 30, 2014 On 28/06/2014 at 19:30, Jp606 said: It's easy, just got remove a few bits first. There are several guides on the internet you can follow. Also you need a thin walled socket to remove/install them. I'm attempting mine again tonight because of the socket issue. I have a long and thin 14mm socket as part of my set, quarter inch drive and it was still too fat, as far as I can see you need a proper 14mm plug socket to make sure it fits or you could be mucking about with different sockets forever, some are thicker than others. The plug socket will have a rubber bung in it aswell so they can be withdrawn properly or you could of course use blue-tac or whatever in your socket that fits. No idea how much these plug sockets cost, couldn't imagine it would be dear but I'm lending one off my mate who is a mechanic. The rest of the job looked fairly easy even for a first timer, just take your time it's not a race and make sure you have no plans for an hour or so.. 1 Quote Link to comment Share on other sites More sharing options...
JEMAN Posted June 30, 2014 Author Share Posted June 30, 2014 Great tips and links guys.........thanks and much appreciated. 1 Quote Link to comment Share on other sites More sharing options...
