Zhorno Posted June 27, 2014 Share Posted June 27, 2014 Randomly was working other day fine , I'm in it now and nothing all standard , any ideas ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 27, 2014 Share Posted June 27, 2014 Randomly was working other day fine , I'm in it now and nothing all standard , any ideas ? Sent from my iPhone using Tapatalk You're in it now ? what are you in ? the sub ? ... I'm impressed ... not many people on here got a submarine Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 27, 2014 Author Share Posted June 27, 2014 I figured out if I literally hit it with my hand next to the sub it comes on but then I go over a bump and it stops again Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stutopia Posted June 27, 2014 Share Posted June 27, 2014 Sounds like something a bit of solder would cure. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 28, 2014 Share Posted June 28, 2014 Sounds like this. http://www.350z-uk.com/topic/85821-how-to-bose-subwoofer-cutout-fix-amp/page__view__getnewpost Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 28, 2014 Author Share Posted June 28, 2014 Thanks for that link it is that , just ordered the relay thing Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 28, 2014 Share Posted June 28, 2014 If you have any question just ask mate. Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 29, 2014 Author Share Posted June 29, 2014 If you have any question just ask mate. Will do never soldered anything before in my life so I may have sum questions Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 29, 2014 Share Posted June 29, 2014 If you don't feel comfortable I can do it for you, just ask if you need. Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 30, 2014 Author Share Posted June 30, 2014 I'll give it a go , to remove the mod do I just use the soldering iron to melt the solder on the back then pull it out ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
cs2000 Posted July 1, 2014 Share Posted July 1, 2014 Yes mate just that. Helps if you have a friend because when you remove the iron, the solder sets again immediately. You need someone to pop the leg out whilst you have the solder in its liquid state, or do as I did on the guide and get it done by snapping the relay off and use some pliars to pull put the legs. 1 Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted July 20, 2014 Share Posted July 20, 2014 I never bothered buying a relay, all I did was wrap a load of insulating tape around it, put it all back together and 18 months later I'm still getting a free back massage, but then again I'm the sort of guy who turns his underwear inside out, so you could say I'm a bit of a tightwad. I'm a tightwad, there you go!! Quote Link to comment Share on other sites More sharing options...
Zhorno Posted July 20, 2014 Author Share Posted July 20, 2014 Well it was only like £3 you really are tight 😂 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Zhorno Posted July 20, 2014 Author Share Posted July 20, 2014 And it worked a treat Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
