SiriusProjects Posted June 25, 2014 Share Posted June 25, 2014 Hi Guys, I am going to be changing the door pillars but can someone tell me how best to remove these and what to use to affix new ones? Thanks. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted June 25, 2014 Share Posted June 25, 2014 The B-Pillars (shiny black plastic)? they just pop off, open the door, stick a flat headed screwdriver behind them and pop them off. As for affix new ones depends on what your doing. Most people just wrap the old ones and pop them back on. Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted June 25, 2014 Author Share Posted June 25, 2014 How are the B-Pillars attached? Are there lugs on these that just clip back in or are they stuck on using some sort of adhesive? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 25, 2014 Share Posted June 25, 2014 There are 3 lugs on each B pillar trim. Be careful that you do not break them on removal. Alex. Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 25, 2014 Share Posted June 25, 2014 Best to replace these clips as I have found (to my expense) once removed they become worn and the female part of the clip becomes slack. No joke intended! Better to replace just to be safe, PM if you are looking to replace these Quote Link to comment Share on other sites More sharing options...
rob63 Posted June 25, 2014 Share Posted June 25, 2014 Best to replace these clips as I have found (to my expense) once removed they become worn and the female part of the clip becomes slack. No joke intended! Better to replace just to be safe, PM if you are looking to replace these Very good advice...from experience CM will have 'em on your doorstep within a few hours Also, a lot easier to accomplish on a warm day when the plastic is more pliable. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 25, 2014 Share Posted June 25, 2014 How are the B-Pillars attached? Are there lugs on these that just clip back in or are they stuck on using some sort of adhesive? Read this link and all will become clear. Link: http://my350z.com/forum/body-interior-exterior-and-lighting-diy/338322-removing-your-a-and-b-pillars.html Quote Link to comment Share on other sites More sharing options...
SiriusProjects Posted June 25, 2014 Author Share Posted June 25, 2014 That's great guys, thanks for the advice. Quote Link to comment Share on other sites More sharing options...
