Mrdeli Posted June 24, 2014 Share Posted June 24, 2014 Hello all, After 18 months without a Z, I have been drawn back! I have been looking at a 2005 standard car. I have looked at the MOT history and it has flagged up the following: Reason(s) for refusal to issue Certificate Nearside Headlamp cleaning device inoperative (1.7.2) Offside Headlamp cleaning device inoperative (1.7.2) Nearside Front abs to flexi Brake pipe excessively corroded (3.6.B.2c) Nearside Front flexi to caliper Brake pipe excessively corroded (3.6.B.2c) Offside Rear flexi to caliper Brake pipe excessively corroded (3.6.B.2c) Advisory Notice issued Offside Front flexi to caliper Brake pipe slightly corroded (3.6.B.2c) Nearside Rear flexi to caliper Brake pipe slightly corroded (3.6.B.2c) Front registration plate deteriorated but not likely to be misread (6.3.1d) Engine covers fitted obscuring some components in the engine bay Could someone help me with the likely costs of carrying out the above and whether they are DIYABLE Many thanks - and hi to all. Mark Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 24, 2014 Share Posted June 24, 2014 For the headlamp washers if both are not working there's a good chance its the pump which is around £30 to £40 new. The rest appears to be brake pipes (the hard lines) so if you are capable of replacing them go for Kunifer pipe and you won't have to worry about replacing them again, the flexi hoses in the advisory list could be replaced with braided lines If you are not confident with brakes though it would be best to leave them to a professional although a good independent should not charge a lot for the above. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 24, 2014 Share Posted June 24, 2014 ^^ What he said. Sometimes the headlamp washers though don't work in cold weather. Mine where sticking during the winter but working fine now so maybe when the MOT was carried out it was something similar?! would be great if that was the case. The brake lines are DIYable if you can bleed the system correctly afterwards and shouldn't cost too much to do. Lot's of options for braided brake lines available from the traders on here like Clark Motorsports above. Not sure what the problem is with the engine covers? would need to see it really to know what they are on about. Good luck. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 24, 2014 Share Posted June 24, 2014 I can't help with most of it, except to say that the MOT tester must have been a right special one: Engine covers fitted obscuring some components in the engine bay There's not much extra covering in the engine bay you'd be able to do! Nissan cover it all from standard Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted June 24, 2014 Author Share Posted June 24, 2014 Thanks guys - great to be back in a forum that gets responses Its the brake pipes that concern me - just trying to access whether its £100 or £1000 job. Thanks Quote Link to comment Share on other sites More sharing options...
JetSet Posted June 24, 2014 Share Posted June 24, 2014 I can't help with most of it, except to say that the MOT tester must have been a right special one: Engine covers fitted obscuring some components in the engine bay There's not much extra covering in the engine bay you'd be able to do! Nissan cover it all from standard Very strange indeed. Pete Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 24, 2014 Share Posted June 24, 2014 I can't help with most of it, except to say that the MOT tester must have been a right special one: Engine covers fitted obscuring some components in the engine bay There's not much extra covering in the engine bay you'd be able to do! Nissan cover it all from standard As a complete an utter guess here, I suspect the first thought for the headlight washers not working would be the fuse, but tester's aren't permitted to remove parts during the test, so with there being a fusebox hidden beyond the battery cover... Wild stab in the dark maybe, but that'd be my first guess. Quote Link to comment Share on other sites More sharing options...
Mudman Posted June 24, 2014 Share Posted June 24, 2014 Someones having a tin bath Quote Link to comment Share on other sites More sharing options...
thedon Posted June 24, 2014 Share Posted June 24, 2014 Engine covers fitted obscuring some components in the engine bay I always get this advisory. I think it's backside covering... the tester isn't obliged (or maybe even permitted) to remove covers, so if you subsequently have an accident due to something that was under a cover and that he didn't see, that is his get out of jail card. Quote Link to comment Share on other sites More sharing options...
gsexr Posted June 24, 2014 Share Posted June 24, 2014 Covers obscuring is just an arse covering execise that they use today. My sons focus has had that mentioned twice. Its not a concern just the tester saying he cant see anything thats covered so no worrys. Quote Link to comment Share on other sites More sharing options...
Hooch Posted June 24, 2014 Share Posted June 24, 2014 A lot of the time you can just clean up the lines with a wire brush and then they pass fine... Quote Link to comment Share on other sites More sharing options...
baggedZ Posted June 25, 2014 Share Posted June 25, 2014 In regards to £100's or £1000's for the job in hand. Definitely looks to be more on the £100's side. I also suffered from corroded brake pipes and the garage i used only charged me £50. The other parts you may be lucky if you can get them salvaged, not sure what the dealers price would be. Quote Link to comment Share on other sites More sharing options...
Hooch Posted June 25, 2014 Share Posted June 25, 2014 I'm pretty sure if you don't have headlight washers/switch then it doesn't count on the MOT Quote Link to comment Share on other sites More sharing options...
Lexx Posted June 25, 2014 Share Posted June 25, 2014 Half a dozen brake pipes, fluid, bleeding etc will be around £200-300 at a good independent. The pipes themselves are cheap. It's the labour that costs. Quote Link to comment Share on other sites More sharing options...
Payco Posted June 25, 2014 Share Posted June 25, 2014 Suprised he didnt put "No front facing rear seats" as an advisory... What a tool... Quote Link to comment Share on other sites More sharing options...
Jp606 Posted June 25, 2014 Share Posted June 25, 2014 I can't help with most of it, except to say that the MOT tester must have been a right special one: Engine covers fitted obscuring some components in the engine bay There's not much extra covering in the engine bay you'd be able to do! Nissan cover it all from standard Very strange indeed. Pete I had this on my MOT a couple of months ago. I got 4 'advisories' as follows: Under-trays fitted obscuring some underside components Engine covers fitted obscuring some components in the engine bay Non standard exhaust fitted Non standard coil springs fitted Wtf?! Got to be the most anal MOT tester in the world. What about all the other 'non-standard' things fitted to the car? None of these should be advisories. Quote Link to comment Share on other sites More sharing options...
