Tommo79 Posted June 23, 2014 Share Posted June 23, 2014 So I took my car last week to a local body shop to have the front bumper repsrayed due to stone chips and also the rear quarter panel resprayed due to bubbling around the wheel arch. The colour where it has been done is darker than the rest of the car, and has quite an obvious purple hue to it at certain angles when the sun hits it, it really shows up though under artificial light from torch, car headlight etc. So I spoke to the paint shop and they said they definitely used the correct paint code, and that the colour is a flippy colour. They said I can take the car back to them to look at, they tried to blend the bumper into the front wheel arches, they have said they may need to blend into/paint the bonnet aswell. Anyone had this problem with the azure before? Is there anything that I could check that they are doing to make sure they get a better colour match if they spray it again? It seems that there is only one paint code for this colour, so I'm not sure what else can be done to get a better match? Any advise would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
hensh65 Posted June 23, 2014 Share Posted June 23, 2014 The paint colour will be correct. The car isn't exactly just out the factory so the paint will be faded. When I got my new bonnet they had to spray the front bumper and sides so they werent blending to 3 edges. Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted June 23, 2014 Share Posted June 23, 2014 All down the sprayer bud, but azure is know for this problem. That's why all re sprayers want to paint whole front end or the rear end. Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted June 23, 2014 Share Posted June 23, 2014 Same problem with mine, front end bonnet and passenger door were done and the shade is slightly darker. I did the chips on my skirts with aerosol with the paint code and that is the same shade as the panels I had painted, I think there may be a few different shades where the OE paint seems to be lighter than the mixes. Quote Link to comment Share on other sites More sharing options...
Tommo79 Posted June 23, 2014 Author Share Posted June 23, 2014 Yeah, it's the purple hue in it that's doing my head in mainly, rather than the actual darkness of the colour. I took it to another body shop for a second opinion, and he said it's almost as if there is too much red in the colour of the respray. Quote Link to comment Share on other sites More sharing options...
eatonm90 Posted June 23, 2014 Share Posted June 23, 2014 What I did notice when using aerosol was if I put a heavy build up of base before the clear coat it did have a very slight purple tinge at certain angles, but if I powdered it in to blend the purple went...not a painter so not quite sure how it all works.. Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted June 23, 2014 Share Posted June 23, 2014 Azure is a biatch to match! Mine is currently getting new front and rear bumpers... 3rd time it's been in the garage this year... so god knows how many shades of blue mine will be in the end! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2014 Share Posted June 23, 2014 I remember replying to something similar a while back, I had the stone chips sprayed just before last years Le Mans. My painter was so unhappy with the match off his own back he went to factory & had it blended just so & re did it a week later. 1 year on, needs doing again I note. Paddy, I did offer you some of this for matching. Quote Link to comment Share on other sites More sharing options...
Tommo79 Posted June 23, 2014 Author Share Posted June 23, 2014 (edited) just been out with the torch, as you can see the purple hue is there: http://postimg.org/image/f5xp3eb4v/ Edited June 23, 2014 by Tommo79 Quote Link to comment Share on other sites More sharing options...
Ricey Posted June 23, 2014 Share Posted June 23, 2014 Also it they use the wiper washer cap as the match plate under the spectrometer it'll be matching it from a plastic panel and not metal......I say that as the washer cap is the easiest thing to remove so I reckon it gets used a lot. Azure is an unholy nightmare to match Quote Link to comment Share on other sites More sharing options...
martinmac Posted June 23, 2014 Share Posted June 23, 2014 As has been said the Azure is not easy to match. This is why many traders will not have parts sprayed before posting them off. Quote Link to comment Share on other sites More sharing options...
The Seasider Posted June 23, 2014 Share Posted June 23, 2014 Yup, I can confirm you'll be very lucky to get an exact match. There's several different colours on mine! That really does look too purple though - you're asking a lot for a perfect match, but that doesn't even look like a good match. I do a bit of spraying and it is a perennial problem getting colours to match - for all the reasons people have mentioned. That's why they like to spray full sides / ends - so people aren't disappointed...usually. Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted June 24, 2014 Share Posted June 24, 2014 Paddy, I did offer you some of this for matching. Thanks mate, it was appreciated, but wasn't practical at the time just before Wales. Besides, the front had already been resprayed so doubt it would have still matched. I also hadn't planned on being crashed into a few weeks later! Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 24, 2014 Share Posted June 24, 2014 Mine had bonnet, 1 front wing , door and rear quarter and both bumpers done , the other panels around are a perfect match Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 24, 2014 Share Posted June 24, 2014 Here is front ( the side were car wasn't sprayed) only bumper and bonnet. And here is rear bumper into quarter panel . Colour match is perfect Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Tommo79 Posted June 24, 2014 Author Share Posted June 24, 2014 yours does look really good to be fair. In some light mine doesn't look too bad, just slightly dark, which I could live with probably. What I can't live with is the purple colour that shows up when the sun catches it at kind of a side on angle in the evening or early morning, and also shows up really bad under artificial light (car headlight, torch etc) I'm going back there this saturday, so will just have to say I'm not happy and want it doing again. If they used the right paint code, I don't know how it has ended up with the purple hue to it? as the original paint doesn't have that in as far as I'm aware? Quote Link to comment Share on other sites More sharing options...
Zhorno Posted June 24, 2014 Share Posted June 24, 2014 Well maybe the company or components they are using are not very high quality , my friend who done my car said he ordered the expensive paint in comparison to what they normally use. I'm not sprayer so I don't really know what the difference would be but mine is spot on Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
baggedZ Posted June 24, 2014 Share Posted June 24, 2014 Sounds like a nightmare. Glad i got grey over the blue when i had to make the choice. Had some bumper scuffs treated and came out a treat. Quote Link to comment Share on other sites More sharing options...
Tommo79 Posted July 22, 2014 Author Share Posted July 22, 2014 Had this re-done by them a couple of weeks back, and it does look a lot better second time round, the guy from the body shop actually got the guy from the paint manufacturer that they use, out to have look at it with him. Quote Link to comment Share on other sites More sharing options...
Zhorno Posted July 22, 2014 Share Posted July 22, 2014 All sorted then ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tommo79 Posted August 2, 2014 Author Share Posted August 2, 2014 Yes, sorted now. Quote Link to comment Share on other sites More sharing options...
