Decent catch can hose?
Arran
Morning all
Fitted my oil catch tank before the ring trip but the hosing I had was not up to the task at all, you could hear the vacuum inside the hosing and as soon as you squeezed the hose it would stay closed. I reckon I need a stronger reinforced hose. What are you guys with catch tanks using?
Preferably id like blue hosing but could go clear if needed
Cheers
Arran
Wonder if the samco stuff will do the trick if its like my intake hose from samco then I should be more than up to the job. Fuel hose is a good idea though
I bought Gates fuel/oil hose. Doesn't come in pretty colours but it's tough stuff. :D
Link: http://www.ebay.co.uk/itm/GATES-Reinforced-Fuel-Hose-Heat-Oil-Resistant-4mm-5mm-6mm-7mm-8mm-10mm-ID-/330803508813?pt=LH_DefaultDomain_3&var=&hash=item4d056cf64d
Was looking at getting that oil catch can myself http://www.ebay.co.u...=item233c1b90e8
Is there any real benefit on a n/a 350z?
You may find this a useful read; http://www.350z-uk.com/topic/58175-oil-catch-can-tested-and-proven/
Don't think it's massively beneficial on an n/a set up but it can't hurt. Graham (glrnet) has one on his n/a Zed so maybe ask him. :thumbs:
