BLINDS122000 Posted June 18, 2014 Share Posted June 18, 2014 Hi all My front bumper is starting to look a mess with millions of stonechips and also there seems to be a split near the badge. I dont really want to change the OEM look too much. I do like the Nismo V1 bumper but I have the HR model and believe the washer jets dont fit but without them they will fail MOT? Anybody have any good ideas for replacement? Cheers Alex Quote Link to comment Share on other sites More sharing options...
jumping350 Posted June 18, 2014 Share Posted June 18, 2014 (edited) you could cut holes in the V1 for the jets?? have a look here http://www.350z-uk.com/topic/72458-nismo-v2v3-and-headlamp-washers/ Edited June 18, 2014 by jumping350 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 18, 2014 Share Posted June 18, 2014 Respray? Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 18, 2014 Share Posted June 18, 2014 My V2 has the mounting points for washer jets, it shouldn't be a tough job to make the holes for them. Quote Link to comment Share on other sites More sharing options...
Payco Posted June 18, 2014 Share Posted June 18, 2014 As Bulletmagnet suggests, re spray. Should only be about £200.00. Payco Quote Link to comment Share on other sites More sharing options...
hensh65 Posted June 18, 2014 Share Posted June 18, 2014 Aftermarket bumpers don't have any space for washer jets, I don't think they have been a problem passing MOT Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 18, 2014 Share Posted June 18, 2014 The V1 is the same shape as the OEM bumper so the washer jets will fit perfectly once the hole is cut out But according to the mainland MOT procedure, the washers only have to work if fitted, so if you fit a V1 without washers, you can't fail for them not working if they're not fitted Over here in NI ours states differently, it says where HID headlights are fitted, the car MUST be fitted with headlight washers which must work. But on Saturday I got through the MOT with my V2 and no washers. The tester asked if I had washers, I said no, they asked if they were aftermarket lights, I said no, I passed Quote Link to comment Share on other sites More sharing options...
Keyser Posted June 18, 2014 Share Posted June 18, 2014 JDM does not have washer jets out of the factory - They pass MOT. Mine has never failed MOT for no washer jets either (aftermarket bumper) 1 Quote Link to comment Share on other sites More sharing options...
BLINDS122000 Posted June 18, 2014 Author Share Posted June 18, 2014 (edited) Cheers for the replies If im ok not to have the washers for MOT then great, because i find them a pain anyway and don't use them. Might go for the V1 replicas RT Performance are selling Edited June 18, 2014 by BLINDS122000 Quote Link to comment Share on other sites More sharing options...
