Boot release
skahigh
Only a very small issue but, on occasion, if I press the boot release button the boot will unlock and pop open but is then stuck if I try to lift it. I have to press the boot release again.
Any ideas why this happens? Is it just the weight of the boot not allowing it to lift properly or do I need to hold the boot release button slightly longer?
Replacement struts won't assist with the pop, the angle is too flat for that. Rubber washers inside the pop spring covers or sticky bumpons on the oustide of the pop spring covers will held. Boot weight removal helps both and increases MPG and makes the car faster ;)
Edited by SuperStu
