Interior scratches
skahigh
Looking at this post in the zeds for sale section I noticed the plastic around the door handle seems to have a lot of little scratches.
My car suffers exactly the same as well paint having come off the button to open the compartment above the stereo.
Is this a common problem to all zeds, a particular model year or just an odd coincidence? My car is not exactly heavily used at only 34k miles in 7 years!
Common problem, people have plasti-dipped theirs however its not hard wearing.
Best to sand down and spray or buy new.
...or have it hydro dipped. ;)
Any idea on cost? Where to get it done?
How easy are the door handles to remove? I havn't been able to work out how to get the button off the centre compartment door.
This is a common problem, frequently reported here on the forum.
The Zed interiors are quite vulnerable to scratches and general wear and tear.
If you use search, you will find that:-
Plastidip isn't that durable.
Sanding down and then matt black paint spray is a cost effective option.
Wrapping/hydro dipping seems to be the most durable option
If it helps, I recently removed the drivers side interior door pull, sanded it down and sprayed it matt black.
It now looks great and I'm pleased with the overall appearance.
I was rather hesitant to do this, but using the guides on the forum, I found it quite easy to do.
It;s worth trying it for the improvement it makes..
Thanks, I shall search unless you can point me to a useful resource. :)
Cost for hydro dipping the drivers side switch/door pull panel, passenger side switch/door pull & passenger side grab handle was £70 all in from AquaGraphix for the 3 parts on my Zed.
Link: http://www.aquagraphix.co.uk/
Link to my thread about it; http://www.350z-uk.com/topic/86048-hydro-dipped-interior-parts-door-pulls-grab-handle/
Very easy to remove them all. You can see part of it done in my thread but for a more thorough explanation have a look at the link below. It's for doing a speaker install but shows you exactly how to remove the door pulls etc.
Link: http://liljerk.morpheus.net/350Z/front_speakers/
Hope that helps. :thumbs:
