Wax / seal top up
Dean_1983
So today I spent some time cleaning and topping up the 350
I've ordered some Zano Grand Finale seal spray ... But in the mean time I have some megs nxt spray wax
Started with the usual ,
Snow foam
Using PH neutral snow foam
Then washed wheels and tires using this crazy good stuff my local car wash sells
Then washed car using 2bm and micro fibre noodle wash mitt
Then applied this
Some finished pics
Over all ... Not that impressed with the megs spray wax ... Can't see it giving much protection , I used it over a very strong sealant to see if it would add any extra gloss ... I couldn't see any difference
Still I enjoyed my 3 hours cleaning the car .. Oh and always as soon as I'm done .. It rains :)
I've used quite a few of the megs products and in general I think they are great, however I agree with your comments about the tech wax. Ive found in general that spray versions are not very good at the job except for spot detailing. Indeed I would suggest that you put the bottle of this wax in the boot and use it for small quick maintenance jobs on the road, bird droppings etc etc. However have you tried megs ultimate paste wax, now that's a very good wax.
A small edit, be careful if you think by adding layers that you will build up extra shine. The professional view from the manufacturers is that because paint is porous it only needs one wax layer to soak in and seal, Most people try 2 coats to catch the bits they missed in the first go and then some top sealant to try and achieve the wet look.Anyway not trying to teach you to suck eggs but a lot of drivers don't know about paints ability to soak up .
Edited by cmck13
Na agree with you 100% seems one good even layer is good and strong enough to give protection ... That's a good idea to keek the spray wax for those jobs ! Was going to buy some waterless Eco wash for that !
