flakey Posted June 11, 2014 Share Posted June 11, 2014 theres air getting into my cabin from the drivers side just above the window of my roadster,do you guys think my window needs adjusted?it would be appreciated if you could give me some advice,the passenger side seems more air tight than the drivers. heres some pics. 1st pic is passengerside,2nd is drivers side Quote Link to comment Share on other sites More sharing options...
Will370z Posted June 11, 2014 Share Posted June 11, 2014 Is the window tight into the rubber on that side? If it is i doubt there is much you can do. Fingers crossed a window adjustment should sort it. There should be posts on the forum to guide you through how to adjust the window Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 11, 2014 Share Posted June 11, 2014 Drive with the roof down, and you will never notice 2 Quote Link to comment Share on other sites More sharing options...
flakey Posted June 11, 2014 Author Share Posted June 11, 2014 in Scotland grundy lol,just seems that the passenger sides a bit tighter and theres no noise from that side,looks like im gonna have to try take the door card off and adjust the window,is this straight forward guys never done bugger all to my previous cars always used the local garage. 1 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 11, 2014 Share Posted June 11, 2014 Double check there are no breaks in the seals. Could try with roof down, windows up, and check each side are level etc with a reference point. 1 Quote Link to comment Share on other sites More sharing options...
Ridz Posted June 11, 2014 Share Posted June 11, 2014 Have you checked that the drivers side window fully resets? It appears that the pax side is ok, but the drivers side doesn't fully close. The side windows on roadsters drop slightly when you open the door and then close slightly when the door is closed again. Hopefully, just a window reset is required. 1 Quote Link to comment Share on other sites More sharing options...
