Grundy Posted June 9, 2014 Share Posted June 9, 2014 Okay first off, if you're going to comment, 'why are you doing this' or 'This can't be done' then don't bother commenting please, Think outside the box peoples! So if you want my money, be a bit more helpful please Rant over, 2 Things What's the offset of the front brembo discs? I.e if you measured from the rear of the disc to where the hub connects to. 2nd question Can anyone supply me 2 discs with a larger offset? With some measurements and custom adaptation, I have about 6-9mm room behind the standard disc for it to move back. Thus moving the Calliper back, thus getting my wheels on Quote Link to comment Share on other sites More sharing options...
flyboy Posted June 10, 2014 Share Posted June 10, 2014 I fully understand what your proposing but wouldn't a 10mm spacer be easier, this is what they are meant for after all. Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 10, 2014 Share Posted June 10, 2014 I fully understand what your proposing but wouldn't a 10mm spacer be easier, this is what they are meant for after all. Yes, but then the tread of the tyre will be sticking outside the arch. Might be worth PMing CS or Clarks who will have discs handy to measure for you and could almost certainly get you what you need Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 10, 2014 Share Posted June 10, 2014 The offset or height is 49mm. Not sure if there would be a similar disc with a larger height would be available but if not what about using a two piece rotor and having someone make custom bells? 1 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 I fully understand what your proposing but wouldn't a 10mm spacer be easier, this is what they are meant for after all. I need a spacer going the other way Wheel fills the arch no problem, but doesn't clear the Calliper, so if I push the disc back, then I have clearance without going outside the arch. The offset or height is 49mm. Not sure if there would be a similar disc with a larger height would be available but if not what about using a two piece rotor and having someone make custom bells? Thanks Ewen, good shout, I'll speak to my guy and see if he can get some bells made up or has some contacts. Are you able to supply the Rotors? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 10, 2014 Share Posted June 10, 2014 Yes I could supply DBA 5000 rotors only for the 350Z or DBA have a huge range of flat discs of various dimensions that we could possible get Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 Yes I could supply DBA 5000 rotors only for the 350Z or DBA have a huge range of flat discs of various dimensions that we could possible get Okay cheers, going to get a quote on getting the bells made up. But going to see around first to try and find some 'taller' Discs. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 10, 2014 Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 10, 2014 Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C C.2131? There's been a LOT of plans now Sent from my C6903 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C C.2131? There's been a LOT of plans now Sent from my C6903 using Tapatalk Shhhh This plan is going to work! Need 13mm Clearance to get the wheels on. I have between 6-9mm room behind the current disc. I have a bracket made to move the mounting position of the Calliper. With a disc height of 57mm, then I will only need a 5mm spacer and the wheels will be on! What could possibly go wrong? Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 10, 2014 Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C C.2131? There's been a LOT of plans now Sent from my C6903 using Tapatalk Shhhh This plan is going to work! Need 13mm Clearance to get the wheels on. I have between 6-9mm room behind the current disc. I have a bracket made to move the mounting position of the Calliper. With a disc height of 57mm, then I will only need a 5mm spacer and the wheels will be on! What could possibly go wrong? Potentially... Lots Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C C.2131? There's been a LOT of plans now Sent from my C6903 using Tapatalk Shhhh This plan is going to work! Need 13mm Clearance to get the wheels on. I have between 6-9mm room behind the current disc. I have a bracket made to move the mounting position of the Calliper. With a disc height of 57mm, then I will only need a 5mm spacer and the wheels will be on! What could possibly go wrong? Potentially... Lots BOOM! This bad boy has the Discs I want Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 10, 2014 Share Posted June 10, 2014 But going to see around first to try and find some 'taller' Discs. Haven't you been doing this for best part of a month?! That was LARGER discs Found them not a problem, but after testing it with mock ups, it didn't move the Calliper enough So onto Plan C C.2131? There's been a LOT of plans now Sent from my C6903 using Tapatalk Shhhh This plan is going to work! Need 13mm Clearance to get the wheels on. I have between 6-9mm room behind the current disc. I have a bracket made to move the mounting position of the Calliper. With a disc height of 57mm, then I will only need a 5mm spacer and the wheels will be on! What could possibly go wrong? Potentially... Lots BOOM! This bad boy has the Discs I want Christ. Good luck. Let me know if you need any help Sent from my C6903 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 10, 2014 Share Posted June 10, 2014 Is that a Mazda CX7? If so DBA list a disc 1 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 It's only for test purposes http://www.eurocarparts.com/ecp/c/Mazda_CX-7_2.2_2010/p/car-parts/brakes/brake-friction/brake-disc/?104681538&1&dc840dd91d6bbccb6a7e127d6c79d7690a64a2fb&000027 Found these, waiting to see if I can get cheaper on trade. If they fit I can then get the exact measurements, As a company has gotten back to me with discs of 330mm Diameter, and 54.7mm Height. Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 Is that a Mazda CX7? If so DBA list a disc Indeed it is, the one on Euro looks really bad But if I can get it cheap, then I can test that it actually works, then go a head and order some DBA from yourself. 1 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 10, 2014 Share Posted June 10, 2014 (edited) Is that a Mazda CX7? If so DBA list a disc Indeed it is, the one on Euro looks really bad But if I can get it cheap, then I can test that it actually works, then go a head and order some DBA from yourself. Hey look, it's grundy's mum edit: and grundy right now: Edited June 10, 2014 by AliveBoy 2 Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 10, 2014 Share Posted June 10, 2014 It's only for test purposes http://www.eurocarpa...0a64a2fb Found these, waiting to see if I can get cheaper on trade. If they fit I can then get the exact measurements, As a company has gotten back to me with discs of 330mm Diameter, and 54.7mm Height. Won't fit, they're only 18mm thick, OEM are 30mm. Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) Okay Gang, I need your help, found a Company who can Make me up discs ( If no one else can come through with the right sizes.) Who can help me fill in the blanks? Front Brembo Discs Fig1. Fig2. Edited June 10, 2014 by grundy225 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) Fig1 Fig2 1a - 49mm 1b - 324mm 1c - 1d - 1e - 68mm 1f - 1g - 1h - 2a 2b 2c 2d - 66.1mm 2e 2f 2g - 5 x 114.3 Edited June 11, 2014 by grundy225 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 11, 2014 Author Share Posted June 11, 2014 Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted June 11, 2014 Share Posted June 11, 2014 1e is 68mm 1 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted June 11, 2014 Share Posted June 11, 2014 2D is 66.1 2G is 5 x 114.3 Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 11, 2014 Author Share Posted June 11, 2014 2D is 66.1 2G is 5 x 114.3 Trust you to pick one of the easy ones Cheeeers Quote Link to comment Share on other sites More sharing options...
