Tein springs ?
Bodyboarder81
Hi , I've done a search and read some good and bad about the tein springs . I would love to hear from people who are running these springs and mainly to ask how the compare to the standard springs with regards to comfort and compliance on our roads ? They state they drop the car 14/17 .... Is this correct in the real world? Thanks for your help :)
Have them on my car - can't say I notice any real difference in comfort. As for ride height - pretty much as it says on the tin (14/17mm)....hence not to much of a drop that requires other mods (adjustable arms and such).
And they are a pretty green colour as well. :teeth:
Edited by aidan
Had mine on a while, love them. Ride is very OEM, very slightly stiffer but nothing that noticeable. Progressively sprung so stiffen in corners and a perfect ride height for me, struggle on some speed bumps but nothing major. I wouldn't want to be any lower!
Pics http://www.350z-uk.com/topic/75626-my-gm-07-hr-fast-road-build-thread-uprev-remap-update-050614/page__st__40#entry1209032 :)
Edited by Jp606
What he said
I have had them on my Zed for a few years now, no complaints from me.
As mentioned before, ever so slightly stiffer than OEM.
The drop is mild, but does not need the extra mods like adjustable camber arms and bolts like you would if you went lower.
Any camber can be brought back in line with factory adjusters.
Mine were supplied and fitted by Abbey Motorsport
  • 1 month later...
We have them in stock and are a Tein master dealer :)
The UK kits are designed for UK roads others are not, so be wary of kits that seem a lot cheaper on eBay they will be Japanese spec kits designed for their very smooth roads
http://www.350z-uk.com/topic/78817-tein-s-tech-springs-in-stock-for-350z-17350-delivered/
I have had mine on for a while now. Slightly harsher over a rough road and possibly a bit more noisy? Stiffer around corners and I find that when you get a loose back end, the car 'snaps' back in to line better than before.
I got mine from Clark Motorsport, and couldn't recommend them enough. :pmclark:
As for fitting them, my thread should give you a rough idea of what is involved. I would also recommend getting spacers to compliment the stance. 25mm rear, 20mm front. No need for arch rolling or adjustable camber arms.
edit: link would help http://www.350z-uk.com/topic/80089-harmlu-build-project-to-fi/
Edited by HARMLU
