MX5 Build thread - No hairdressing equipment left in vehicle overnight
longsh07
I had a 106 GTi as a second car which I had been building up to use as a track car. Due to a slight fire (its French, what did you expect) I have decided its time to part and get something less French, and by less French I mean Japanese. So I went out and brought a hair dressers car but its really impressed me so far! :teeth: Let me introduce you to my new toy, 04 Euphonic MX-5.
Advert Photo
Update photo
She's not fast, but she sure as hell sticks to the road. Good fun for a B road blast on a sunny day.Its a 1.8 with a 5 speed box and an LSD. Also has the bigger brakes (270/276mm) but the rear pads seem to be slightly different from the sports MX5's pads.Plan is to track her as well as to give my Zed a rest over winter. Got a TR Lane roll bar on order and had some some service bits (oil/filters/brake pads) delivered already.
Change Log
  • June 14 - Attempted to fit EBC Greenstuff rear pads only to discover the rear piston rubbers were mangled.
  • July 14 - Fitted reconditioned rear callipers, replaced section of front to rear brake hard line, new front brake slider pins, rubber boots and retaining bolts, braided brake lines and finally fitted EBC Greenstuff pads all round. Also replaced the air intake filter and heaedunit.
  • Aug 14 - TR Lane GPV roll bar fitted. Fresh oil and oil filter. Brought clear (the tinted light smoke) side reflectors and indicators. Fitted LED bulbs (including converting reflectors to side markers) and chrome covered front/rear indicator bulbs.
  • Sept 14 - Rota Grid-V alloys (15x7 ET20) with Michelin Pilot Sport 3's (195/50/15)
  • Oct 14 - Replaced electric aerial and base with manual base and stubby aerial. Also painted some of the tyre lettering. Sprayed the air vent surrounds purple. Sprayed rear tow hook purple and fitted.
  • Nov 14 - Changed the registration and sprayed grill.
  • Dec 14 - Fitted Xenon effect low/high beam bulbs
  • Mar 15 - Sprayed more interior parts purple. Sprayed and fitted purple front tow hook (removed baby teeth). Fitted fire extinguisher. Fitted cold air feed. Had Cobra exhaust fitted by Japex in Kings Langley.
  • Apr -15 - Sprayed windscreen surround and wing mirrors matt black (Foliatec spray film - Its basically plasti dip). Sprayed door cars purple. Replaced broken Sony 170W 2 way speakers with a set of Pioneer 230W 2 way speakers. IL Motorsport pedal covers.
  • June 15 - Reupholstered passenger seat in black leather, resprayed purple interior bits a different shade of purple (same as tow hooks and cold air intake), changed washer jets to fan style Ford jets.
Future Plans
  • Roddisons brake pads and new OE discs
  • Sport seats (Recaro Speed)
  • Track day tyres (Federal 595RSR / Toyo R888)
  • Coilovers (Meister-R Zeta-S 6/5 kg/mm, BC Racing BR Series 6/5 kg/mm, Gaz Gold 400/300lbs)
  • Team Dynamics Pro Race 1.2's (15x7 ET23)
  • If I need a new clutch - Exedy stage 1 clutch and lightweight flywheel.
Oh and for those who are interested, I did fix the 106. £6 sensor and it was up and running again. Sold it on to someone else wanting it as a track project so it went to a good home :)
Edited by longsh07
We look after a few MX5s, great track toy, do let us know if we can help with parts in the future... :)
Good to know, im sure ill be in touch ;)
MX5Nutz and MX5OC are two sites to check out if you haven't already.
Signed up for the first, did make an intro post but got like 1 reply from another newbie.
Will try MX5OC as well at some point.
Should be a great fun rwd track day toy.
Not really a fan of these but I've heard that they can be very capable and just good old fashioned fun on track. :drive1
I've been pretty impressed so far I must admit. Not been on track but it take take some of the tight corners near me at the same speed if not faster than my Zed.
Edited by longsh07
I had this model a few years ago as a second car, I think they are great, tested by time, with no bad habits, not fast but leaves many others behind when they hit the bends. Recommended for people on a limited budget who can't make their mind up.
Thought I'd have a crack at changing the rear pads as they were the only advisory on the last MOT.
Nice simple brakes made the job quite easy but as usual, these jobs throw up something else that needs doing...
Passenger side came out nice and easy, small split in the piston rubber. Nothing serious but need to address it at some point. Filled it with grease for now.
Greenstuff pads. These get a lot of mixed reviews so I decided to try them for myself and make up my own mind.
Then round to the drivers side and...
Great. Piston is getting sticky and you can see the state of the rubber. I'm not happy leaving it and would be concerned about it on a track day.Not going to muck about learning how to rebuild the calliper myself so I've ordered a set of professionally reconditioned callipers, one for each side. Also a good excuse to fit braided lines while the brakes are off.
Edited by longsh07
^^ That's a bummer but you'll be better off in the long run with the reconditioned calipers & braided lines.
I used to run EBC green stuff pads on a Rover 214si that I tracked and they worked well on it. ;)
That's what I figured. Its only going to take one bit of crap to get in behind the rubber and jam the brake on/off.
Also good to know about the pads, they've got to be better than the worn out old ones either way :lol:
Well the pads definitely worked better for me than the standard 1992 Rover OEM pads. :lol:
Although after one particularly exuberant track session around Castle Combe the front where smoking a bit when I went it to the pits. :surrender: Probably more due to the heat the discs where giving off though. :D
  • 1 month later...
Update time:
Had some issues with the brake fitting.
Fronts - Pads went on OK however the torque setting for the slider pin bolt I found online were massively wrong. Not sure if I stripped the thread or it had been done before but ended up replacing the slider pins, bolts and rubber boots just to be safe. Braided lines went on a treat.
Rears - Fitted the new calipers, pads and braided lines no problem however the little steel distribution block was leaking brake fluid... Ended up replacing a section of the factory pipe with copper nickel pipe and sticking on a new union however it was still leaking!! :rant: Ended up going back to MX5parts and they sent me a new block. Didn't take a photo but looking at the two blocks side by side the leaky one had a smaller hole in the threaded ports than the new one so I can only assume the one I got couldn't pass enough fluid through it (might have been the block for the smaller brakes) and so it was leaking out the weakest seal. Either way, replaced the block and no more leaks :)
New caliper, pads and brake lines. That little block is the old leaky one.
Close up with the new pipe fitted
Pipe run and join
On another note I also replaced the air filter and fitted a Pioneer AppRadio2
Lightning connector in arm rest storage box
Next on the list - Roll bar and oil + filter change.
  • 1 month later...
Aug 14
Update time - Got some clear reflectors which I decided to tint in a light smoke colour. Really pleased with these, just need a HID kit now to get rid of the yellow dipped beam.
Roll bar fitting, step 1, remove speaker wind blocker
Step 2, remove trim, parcel shelf and carpet
Step 3, hack about 4" off the parcel shelf mounting points on the seatbelt towers and neaten up the mess you've made.
Step 4, figure out what spacers are required to close the gap between the roll bar and the towers then drill the holes
Step 5, bolt seatbelt tower bolts back in place, mark locations to drill, jack up rear, remove wheels and arch lines, drill out hole to 10mm
Step 6, Fit spacers, bolt through seatbelt towers, bolt through floor pan and fit reinforcing plates on rear mounting points, paint to prevent rust.
Step 7, trim parcel shelf, sound deadening and carpet then refit everything
Edited by longsh07
  • Like 2
Good job on the roll cage and the smoked side lights do look really good. :thumbs:
Thanks chap, really pleased with how close to body colour they are. One of the other options was to just paint the originals body colour but thought a little bit of extra light wouldn't do any harm!
you definitely did the right thing by getting new pistons and rubbers. You could've pushed out the piston and given the corrosion some wet and dry action but that's not always the best idea as crap can get in to the imperfect areas that have been rubbed down new rubbers or not. They would've ended up sticking again at some point. Good call, and at least you don't have to worry about it now you're going to track it. :thumbs:
