SunGodRA Posted August 8, 2007 Share Posted August 8, 2007 Everytime I turn my aircon on there is a damp smell for the first 5 mins or so, then it subsides - any ideas?? Quote Link to comment Share on other sites More sharing options...
H5 Posted August 8, 2007 Share Posted August 8, 2007 First, make sure the drainage hole isn't blocked. Next, having it repressured / cleaned out may get rid of any stale water kicking about in the system. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 8, 2007 Share Posted August 8, 2007 you my have bacteria build up on the aircon which is common if you don't use it often try this and it will sort it out. You can get it off the net or halfords http://www.commaoil.com/News/newsairconcleanhtm.htm Quote Link to comment Share on other sites More sharing options...
James350z Posted August 8, 2007 Share Posted August 8, 2007 This has just started happening on mine aswell. The smell is really bad for a few minutes. Will the Stealers clean it out? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 8, 2007 Share Posted August 8, 2007 see above Comma Air Conditioning Cleaner Cladosporium, Penicillium viridicatum and Aspergillus - just some of the hard to pronounce fungal spores that might be co-habiting in your car's air conditioning unit and increasing your chances of suffering from "Sick Car Syndrome". Scientists have discovered that motorists are susceptible to headaches, flu-like symptoms and even asthma attacks as a result of the micro-organisms quietly multiplying in the moist atmosphere of a vehicle's cooling system. And, if that wasn't bad enough, the fungi deliver a rather nasty, and lingering, smell in the process. In response, car care manufacturer, Comma, has launched an innovative, cost-effective solution, Air Conditioning Cleaner. Developed to sanitise and deodorise the cooling system, each canister contains a unique biocide, tested to meet European BS EN 13697 standards, to kill all common bacteria, fungi, mould and even viruses like e-coli. Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 8, 2007 Share Posted August 8, 2007 This has just started happening on mine aswell. The smell is really bad for a few minutes. Will the Stealers clean it out? At a price. Not a warranty issue AFAIK. Quote Link to comment Share on other sites More sharing options...
SunGodRA Posted August 8, 2007 Author Share Posted August 8, 2007 any idea where the drainage hole is?? Quote Link to comment Share on other sites More sharing options...
H5 Posted August 8, 2007 Share Posted August 8, 2007 In the engine bay just behind the engine IIRC. There's a tube from the air con unit to drop the fluid on the ground. Is the car leaving a wet patch after use (Jay, Louis - behave!! )? Quote Link to comment Share on other sites More sharing options...
nixy Posted August 8, 2007 Share Posted August 8, 2007 I agree with the aircon comment. You need to run your aircon regularly all year round to keep it in good working order and stop it ponging. You sometimes notice when you've had it running and then switch it off that there's a slight change in smell. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 8, 2007 Share Posted August 8, 2007 run mine all the time. also helps prevent pump from seizing up Quote Link to comment Share on other sites More sharing options...
nixy Posted August 8, 2007 Share Posted August 8, 2007 just out of interest - does it really affect fuel consumption that much? My cabin is nice and comfy if I put both dials on auto with aircon on and set the desired temp but invariably I end up blasting myself with icy cold air then turning it off because mentally I think I'm burning up more fuel. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 8, 2007 Share Posted August 8, 2007 it will factor but I havent worked out if it's cheaper to keep it on or pay for a new aircon pump. I don't intend to work it out either. Quote Link to comment Share on other sites More sharing options...
H5 Posted August 8, 2007 Share Posted August 8, 2007 just out of interest - does it really affect fuel consumption that much? My cabin is nice and comfy if I put both dials on auto with aircon on and set the desired temp but invariably I end up blasting myself with icy cold air then turning it off because mentally I think I'm burning up more fuel. On new S40 we had it made a 6mpg difference, consistently. I don't think the Zed is that bad, but then what's the point in having it if you're not going to use it...... Plus, as Mike says, a new pump would more than take up any savings! Quote Link to comment Share on other sites More sharing options...
sl114 Posted August 8, 2007 Share Posted August 8, 2007 i always used to have mine on, i dont like getting hot when i drive. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted August 8, 2007 Share Posted August 8, 2007 In the engine bay just behind the engine IIRC. There's a tube from the air con unit to drop the fluid on the ground. Is the car leaving a wet patch after use (Jay, Louis - behave!! )? you know me too well My last Z had the same problem, it smells like an old man kind of smell Got the stale water changed and was fine Quote Link to comment Share on other sites More sharing options...
jim Posted August 8, 2007 Share Posted August 8, 2007 I can vouch for the Comma cleaning product - it works well. Quote Link to comment Share on other sites More sharing options...
Beavis Posted August 8, 2007 Share Posted August 8, 2007 I can vouch for the Comma cleaning product - it works well. Must get this done soon as mine is beginning to smell a little as well. Quote Link to comment Share on other sites More sharing options...
GC350z Posted August 8, 2007 Share Posted August 8, 2007 Mine too but new z arrives in 23 days so screw it. Dealers problem now. Quote Link to comment Share on other sites More sharing options...
SunGodRA Posted August 13, 2007 Author Share Posted August 13, 2007 Just to let you know - I bought some Comma @£11.99 and it worked a treat. Apart from the initial disinfectant smell which lasted about a day, the damp smell has completely gone! - thanks for the great advise! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 13, 2007 Share Posted August 13, 2007 no probs Quote Link to comment Share on other sites More sharing options...
