Guest Posted June 2, 2014 Share Posted June 2, 2014 Hi guys, need some advise please as supposed to be setting off for Le Mans next weekend. Fault code PO345 came up,camshaft position sensor, found an old post from Alex which confirmed bank 2. Slightly poor starting now & ESP lights are on. Did some digging & found a diagram which says bank 2 is on the right hand side when facing the car from the front, pulley towards you. Ordered a new sensor from Clarks , bank 1 & 2 are different parts. My mechanics replaced sensor, same fault code coming up. Clarks sent sensor for bank 2 but facing the car it's on drivers side, ie left not right. So, question is, which is bank 1 & 2, I appreciate a more serious fault may lie beneath? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2014 Share Posted June 2, 2014 Update, still need conclusive answer, mechanic just found video on you tube showing bank 2 sensor is on right side ie pax side under inlet manifold, not drivers side as sent? Any ideas folks? Quote Link to comment Share on other sites More sharing options...
Ken Posted June 2, 2014 Share Posted June 2, 2014 In the Owners Manual cylinder numbers are; From front Left from front to back. 1,3,5 Right from front to back. 2,4,6 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 2, 2014 Share Posted June 2, 2014 (edited) On a R/H/D 350Z, Bank 1 is the driver's side and Bank 2 is the passenger side. Bank 1 sensor is straight and Bank 2 sensor is angled. Alex. Edited June 2, 2014 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2014 Share Posted June 2, 2014 Thank you Ken & Alex, from your replies I suspect may have been sent wrong one? Will check re angled/straight tomorrow. Really appreciate your advises, some urgency as don't won't to go kaput en route to Le Mans, or take the shed!!!!! Quote Link to comment Share on other sites More sharing options...
