Advice/help needed
Niko
Right. First problem was my tcs/abs/stability lights all came on. Then I realised my brake lights didn't work. so sorted that thinking that was the problem. But no the lights came back on. To I took it to get plugged in at the garage and it came up with the code c1142 abs pressure sensor circuit fault. so changes that and still no luck. But also now my front brakes are binding/sticking on and seem to get worse as I drive but one the car has been Parker it frees up.
Any ideas?
It may be the servo as well as many other things, however you are only guessing.
Why don't you get a specialist to check your car to get an informed diagnoses.
Servos, actuators and all parts to fix this issue are in stock and good to go same/next day.
Alex. :)
