Hofner Posted May 26, 2014 Share Posted May 26, 2014 Waxoyl Rustproofing For Cars - Clear - 400ml Aerosol Item No: RX1026Rimmer Bros, For all of your Car Parts & Accessories. Waxoyl Rustproofing For Cars - Clear - 400ml Aerosol and more, fast delivery, worldwide. - See more at: http://www.rimmerbros.co.uk/Item Hi, would anyone recommend using this on inside of the wheel arches? In the clear, thanks Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted May 26, 2014 Share Posted May 26, 2014 It's good stuff is that, Quote Link to comment Share on other sites More sharing options...
wizurd Posted May 26, 2014 Share Posted May 26, 2014 I'll be looking to try this stuff out as well sometime. Only issue I've heard is that the surface has to be totally dry before you put this on otherwise you end up trapping moisture in rather than keeping it out. Can anyone confirm that? Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted May 26, 2014 Share Posted May 26, 2014 Waxoyl, whilst still perfectly usable, is a bit old hat these days. I prefer the Bilt Hamber Dynax range to this, personally. Quote Link to comment Share on other sites More sharing options...
Hofner Posted May 26, 2014 Author Share Posted May 26, 2014 Cheers, have been digging around and found this too, is clear spray DINITROL HIGH TEMPERATURE CLEAR WAX 500ml AEROSOL Product Description DINITROL 4010 is a long term engine protection product with heat resistance of more than 200?C. Good adhesion and flexibility on all metal surfaces, rubber and plastic parts. Suitable for engines, engine compartments and vehicle underbody Leaves a hard, transparent film that is resistant to both alkali and acids Is heat resistant at temperatures of more than 200?C Adhesion and flexibility on rubber and plastic parts - at both low and high temperatures OEM product NOT suitable for exhaust manifolds. Have you tried both? Cheers Quote Link to comment Share on other sites More sharing options...
