chalks Posted May 26, 2014 Share Posted May 26, 2014 Hi, Hopefully this is the right place to post this issue.... I picked my Z up a couple of weeks ago, and a few days ago I had a really annoying beeping along with an LED flashing green and red at the bottom of the driver's A pillar: As you can see there's an aftermarket wire there which I have no clue about either. There didn't seem to be any logic as to the red or green flashing, and the beeping. I was hoovering the footwell and found a toggle switch and a very small button. I flicked the switch and I haven't had any beeps since! The switch is right next to the transmission tunnel, kind of close to the OBD port, on the lower plastic cowl under the steering column. Does anyone have ANY idea what it might be??? I've driven a few miles with it on and off and it definitely doesn't switch off the odometer, which is a relief! Any suggestions would be greatly appreciated. I'd like to get rid of that cable hanging down at some point as well... Thanks, Chalks Quote Link to comment Share on other sites More sharing options...
ross27 Posted May 26, 2014 Share Posted May 26, 2014 Complete guess, but could it be a concealed radar detector? Why not send the previous owner a nice letter asking them to email you back? Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 26, 2014 Share Posted May 26, 2014 Almost certainly for a detector of some kind. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 26, 2014 Share Posted May 26, 2014 Welcome to The Forum. . You could post something in "Introductions and Welcome Messages.".. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted May 26, 2014 Share Posted May 26, 2014 I had one of those it releases a bit of petrol over the back wheels to assist with a flaming burn out. Obviously I'm lying. 3 Quote Link to comment Share on other sites More sharing options...
chalks Posted May 26, 2014 Author Share Posted May 26, 2014 Thanks for the replies! And yes I have already introduced myself in the intros section The previous owner has no idea either, and the owner before that is now living overseas so no means of contacting him.... Good shout on the detector though, I'll have a google and see if any kits have bits similar to this! Do you reckon the actual detector would plug in to the loose wire? Failing that, I'll turn off the ESP and see if I get some flames out the back Thanks again for your help Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 26, 2014 Share Posted May 26, 2014 Looks like a 12v power cable to me, probably hard-wired in somewhere. Quote Link to comment Share on other sites More sharing options...
ross27 Posted May 26, 2014 Share Posted May 26, 2014 I would guess there is some kind of detector wiried in, and that power cable is for a sat nav or display of some kind. Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 26, 2014 Share Posted May 26, 2014 Power will be for the detector box. Easy to remove if you get stopped Quote Link to comment Share on other sites More sharing options...
AFTERSHOX Posted June 11, 2014 Share Posted June 11, 2014 Get your multimeter out and probe the power cable (with the switch on and off) - looks like 12v accessory power to me (like radar detector, or Nav?). Not sure about the small button, beeping or flashing LED. Hope you figure it out? Quote Link to comment Share on other sites More sharing options...
gstraw Posted February 6, 2015 Share Posted February 6, 2015 Did you manage to figure this out? Quote Link to comment Share on other sites More sharing options...
chalks Posted February 17, 2015 Author Share Posted February 17, 2015 Hi, sorry been away for a few days.... No I never figured it out!! If I leave the toggle switch on, the LED flashes green after a few mins, and then some time later it flashes red and starts beeping at me.... I've no way to test whether it's a jammer and I don't want to take my dash apart to find out... Quote Link to comment Share on other sites More sharing options...
