Pete87 Posted May 24, 2014 Share Posted May 24, 2014 So as we all know the headlights go cloudy mine were not too bad but still annoyed me so I got a kit in halfords and gave it ago. I need to do the Mrs MR2 so thought I'd try it on mine first. It took abit of time but end results were really good about an hour to do both headlights. Definitely worth the £22 I spent on it. 1 Quote Link to comment Share on other sites More sharing options...
Pete87 Posted May 24, 2014 Author Share Posted May 24, 2014 Sorry I forgot to get before pictures but here is after pics. They were cloudy at the top of the lights. Quote Link to comment Share on other sites More sharing options...
japcarsbrett Posted May 24, 2014 Share Posted May 24, 2014 you should put some wax on the lights now it will shine them up even more and stop any dirt/sun affecting them and make the lights shinier for longer good job though Quote Link to comment Share on other sites More sharing options...
Pete87 Posted May 24, 2014 Author Share Posted May 24, 2014 Yeh I will do thanks. Was waxing the car and it started raining lol. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 24, 2014 Share Posted May 24, 2014 Nice Job.. Its good stuff Meguires. As brett said seal it now. Quote Link to comment Share on other sites More sharing options...
Linus27 Posted May 24, 2014 Share Posted May 24, 2014 I got some of this and on our old Clio it worked a treat. However, on our Scooby it made no difference. I spent an hour on one headlight and it did nothing. Even tried the toothpaste method after and still no difference. Any other tips or is it a case of new headlights? Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 24, 2014 Share Posted May 24, 2014 Cutting compound and a rotary or you could even try wet sanding if you're feeling adventurous Sent from my HTC One mini using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Pete87 Posted May 24, 2014 Author Share Posted May 24, 2014 Few more better pictures in the dry and after a coat of wax Only tips was after the first go on the drivers headlight there were still marks so I did it again, and spent alot of time going over them with the two finer bits of same paper. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted May 24, 2014 Share Posted May 24, 2014 Were they cloudy on the inside to begin with? Quote Link to comment Share on other sites More sharing options...
Pete87 Posted May 24, 2014 Author Share Posted May 24, 2014 No the outside it won't help if it's inside the light unfortunately. Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 24, 2014 Share Posted May 24, 2014 Ive just been delivered the 3m version of this kit. Ill do a full write up before and after when its done! Looks great though mine are reallly cloudy! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted May 26, 2014 Share Posted May 26, 2014 I did mine a couple of years ago using 2500grit wet n dry then gave them a wax and to complete the job I used a marine grade UV protectant clear urethane varnish just to give them that extra protection. They still look the dogs dangly bits. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 26, 2014 Share Posted May 26, 2014 Personally I used GTechnic C4 to seal the lights, works great. Also to cut down on the time factor, I used my DA polisher to do the lights. First used wet&dry 1200 grit, followed by 2000 grit, then DA polisher for rubbing compound, the DA again for the PlastRX, then seal with C4. Total time was 25 mins for both headlights Quote Link to comment Share on other sites More sharing options...
