MREV2 Lower Intake Manifold
Rosssco
I bought this from a member on recently as a bit of an impulse buy, but since realised it's no use to me without a remap, so up for sale.
Looks to be in excellent used condition. Small amount of oiling on the intake runners to indicate it's used, rather than brand new.
Suitable for Rev-up engines
http://www.frsport.com/Motordyne-MREV2-MREV-2-Manifold-TM-Nissan-350Z-Infiniti-G35_p_15701.html
Looking for £220 delivered (UK)
Thanks,
Ross
  • 3 weeks later...
Not wanting to Pi** on your bonfire, this is a good price for what they go for ----- but ----- Anyone can do this to their own lower plenum.
Its a DIY job to turn a std one into this with a grinder and a steady hand.
Its mainly removing material from the top of the drivers side front intake putting a flat on the top of it.
There is a little more porting and finesse on a genuine one but you can get 90% of the gains just with the flat spot.
If you cant afford this then get your grinder out.
You need to flatten both front ports, the one I have was DIY and delivered the same results as the original, but MUST be used with a spacer also. This must be performed on a pre-Revup lower intake and not on the revup intake as the benefit comes from the shorter ports.
  • 2 months later...
