shaunr446 Posted May 22, 2014 Share Posted May 22, 2014 Clutch does come all the way up. Think its stuck. Any ideas Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted May 22, 2014 Share Posted May 22, 2014 Sounds like your slave cylinder is on the way out, assuming you mean doesn't come all the way up? Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 22, 2014 Share Posted May 22, 2014 + 1 As Clark said.. Quote Link to comment Share on other sites More sharing options...
shaunr446 Posted May 22, 2014 Author Share Posted May 22, 2014 Ok cheers guys. Easy/expensive job? Quote Link to comment Share on other sites More sharing options...
Rs2oo Posted May 23, 2014 Share Posted May 23, 2014 I have this I think. Start car cold from say overnight. Drive a shortish journey no problem, pedal good. Next journey is much longer in traffic. After a while, the pedal travel is much longer before the biting point. Thrust bearing a bit noisy at idle until clutch is depressed. On a track day, the pedal went to the floor and I had to scoop it up with my foot. Let the car cool down and it went back to longish pedal travel. I drove the car home no problem about 60 miles. The next day, back to normal. Quote Link to comment Share on other sites More sharing options...
Commander Posted May 23, 2014 Share Posted May 23, 2014 (edited) Thrust bearing a bit noisy at idle until clutch is depressed. This is normal, but everything else you described is not! Master Cylinder problem? Fluid overheating somehow? Edited May 23, 2014 by Commander Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted May 23, 2014 Share Posted May 23, 2014 Ok cheers guys. Easy/expensive job? Not difficult, a new slave cylinder is £83 and you would need to change the clutch fluid at the same time. A braided clutch line is also a good idea. Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted May 23, 2014 Share Posted May 23, 2014 I have this I think. Start car cold from say overnight. Drive a shortish journey no problem, pedal good. Next journey is much longer in traffic. After a while, the pedal travel is much longer before the biting point. Thrust bearing a bit noisy at idle until clutch is depressed. On a track day, the pedal went to the floor and I had to scoop it up with my foot. Let the car cool down and it went back to longish pedal travel. I drove the car home no problem about 60 miles. The next day, back to normal. You should try bleeding the clutch first and changing the fluid, this deteriorates just the same as the brake fluid and with the extra heat generated on track the fluid will start to boil. Quote Link to comment Share on other sites More sharing options...
SwissZ Posted May 23, 2014 Share Posted May 23, 2014 My 350 clutch used to get stuck down all the time when hammering up and down the Autobahn. Exactly the same thing happened in the Infiniti G37 I had as well. The Infiniti tech who had a look at it thought the clutch fluid might be over heating as it was black when he drained it. He wanted to put some super high quality brake fluid in instead but Infiniti wouldn't let him I put it down to Nissan having designed a crap clutch system. Can't wait to find out if it happens with the 370..... Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted May 23, 2014 Share Posted May 23, 2014 Unfortunately Nissan decided to use the same concentric slave setup as the 350Z HR in the 370Z which are proving to be pretty unreliable Quote Link to comment Share on other sites More sharing options...
