Me again - oil pressure
-Bradders-
problem could be lots of things pressure sender,oil pressure relief valve, oil pump, bearings you could always screw a mechanical oil pressure gauge in instead of the pressure sender to check if the pressure gauge is reading ok
and if it is that low i wouldnt be driving it anywhere these engines arent cheap i know i've blown one
Done over 300 miles now and it seems fine still the oil pressure is fine when moving. No loss of power but just sits on 0 at idle? Was fine this morning it idled fine and sat higher but after 10 mins or so the idle drops to 600ish and oil drops too, went on a nice drive in it and its all good just still lots of feedback through the gear stick.
What's the oil pressure reading at 2500 rpm when fully warmed up? It should be around 60. Pressure changes with engine speed not the speed of the car.
