Kuro Posted August 3, 2007 Share Posted August 3, 2007 Hi folks Just a quickie... Although my Zed has (touch wood) never developed a substance abuse problem, I thinking that having a top up bottle of Oil for the Ring trip next month wouldn't be a bad idea Looking over my service logs, it last had service Texaco Havoline Ultra 5w40 just under 1000 miles ago. Now, here's the question... (okay, two) 1. Do I have to use exactly the same brand and type (5w40) to top up the oil? 2. Is this one synthetic? (my last one was) and can I mix the two? 3. (okay, three then ) How do I top up exactly I mean, I take off the cap, and what, just throw some in? I'm guessing I put very small amounts (like what?) in and check the level-o-meter..? Yours Dumbly... K Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 3, 2007 Share Posted August 3, 2007 OK Dumbly here you go You can stay with 5w 40 or use 5w 30 which is what I use. I think what you have is semi synthetic but is doesn't matter as you can mix it anyway. Check it when its cold and add a smallish amount at a time. As a guide, when on the min mark it will take 1 ltr to bring it up to the max. Quote Link to comment Share on other sites More sharing options...
Stew Posted August 6, 2007 Share Posted August 6, 2007 Make sure not only it's cold but the car is on level ground too! Quote Link to comment Share on other sites More sharing options...
