Dave-350 Posted May 19, 2014 Share Posted May 19, 2014 (edited) Will it cause any problems? In regards to speed sensors or whatever, not if they will fit. Edited May 19, 2014 by Dave-350 Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 19, 2014 Share Posted May 19, 2014 what tire width front and rear? Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted May 19, 2014 Author Share Posted May 19, 2014 er, 255 & 235... I am not on about fitment though. I mean will it throw any faults up or anything as such. Quote Link to comment Share on other sites More sharing options...
370Ad Posted May 19, 2014 Share Posted May 19, 2014 Nope. As long as the rolling radius is as near to stock as possible. Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 19, 2014 Share Posted May 19, 2014 er, 255 & 235... I am not on about fitment though.. That's not why he was asking, profile is directly related to tyre width so if you had odd widths then you would definitely have issues. Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 19, 2014 Share Posted May 19, 2014 (edited) Nope. As long as the rolling radius is as near to stock as possible. not so much the sizes but the ratio between each axle must stay to about the same percentage as factory could rock 24s as long as the difference between rear and fronts rolling radius is the same Edited May 19, 2014 by StevoD Quote Link to comment Share on other sites More sharing options...
Gudzy Posted May 19, 2014 Share Posted May 19, 2014 The rolling radius is pretty close with those sizes, you should be fine. I use www.willtheyfit.com, you enter the stock tyre size and the size you are proposing to use and it tell you the percentage difference between the two. 1 Quote Link to comment Share on other sites More sharing options...
370Ad Posted May 19, 2014 Share Posted May 19, 2014 (edited) Nope. As long as the rolling radius is as near to stock as possible. not so much the sizes but the ratio between each axle must stay to about the same percentage as factory could rock 24s as long as the difference between rear and fronts rolling radius is the same So you promise me that I could rock any size wheel/tyre combo I want...... as long as the ratio is kept the same as factory I want see ANY problems? 32's it is then! Edited May 19, 2014 by 370Ad Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted May 20, 2014 Author Share Posted May 20, 2014 er, 255 & 235... I am not on about fitment though.. That's not why he was asking, profile is directly related to tyre width so if you had odd widths then you would definitely have issues. 9J 235 40 19 10J 255 40 19 That is what I was planning. I run 35's currently. Many thanks. Quote Link to comment Share on other sites More sharing options...
JetSet Posted May 20, 2014 Share Posted May 20, 2014 No running problems but 40's on 19" rims won't look as good as 35's. Pete Quote Link to comment Share on other sites More sharing options...
