Niko Posted May 16, 2014 Share Posted May 16, 2014 Hi guys and girls. I've suddenly got all brake and traction control lights on my dash. Not sure if it will be the abs sensor or the abs pump sensor. Or it could be my tyre set up. But what to check first? I'm running 245-40-19 front and 275-35-19 rear if any know what the problem is and what the cost mite be I'm all ears Cheers. Quote Link to comment Share on other sites More sharing options...
Neilp Posted May 16, 2014 Share Posted May 16, 2014 could potentially be the tyres. should be 245/35/19 on the fronts. Quote Link to comment Share on other sites More sharing options...
tomdotc Posted May 16, 2014 Share Posted May 16, 2014 Had the same but somehow didn't come back on when i turned the engine off and back on again. Quote Link to comment Share on other sites More sharing options...
StevoD Posted May 16, 2014 Share Posted May 16, 2014 o sorry there always on sorry mate when you said i thought you mean on off when driving Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted May 16, 2014 Share Posted May 16, 2014 Niko, I waved to you at Japfest when you were leaving and you blanked me bro!! Quote Link to comment Share on other sites More sharing options...
Gudzy Posted May 16, 2014 Share Posted May 16, 2014 I had those come on, it was the brake switch on the pedal. Check your brake lights are coming on. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted May 16, 2014 Share Posted May 16, 2014 My money is on brake fluid low. Check your brake fluid level. If it is not on max, fill it up until it is, they don't like being anywhere below max. Quote Link to comment Share on other sites More sharing options...
japcarsbrett Posted May 16, 2014 Share Posted May 16, 2014 I agree with sam my toyota supra used to do the exact same it acts as a warning so you check everything lol Quote Link to comment Share on other sites More sharing options...
Neilp Posted May 17, 2014 Share Posted May 17, 2014 Check the tyre calculator as i'm pretty sure that those tyre sizes are outwith the front to rear RR % differential Quote Link to comment Share on other sites More sharing options...
Niko Posted May 17, 2014 Author Share Posted May 17, 2014 Cheers guys I'll check. I know stevoD had the same tyre on an had no issues. But I know there zed can be temperamental lol. Quote Link to comment Share on other sites More sharing options...
Niko Posted May 17, 2014 Author Share Posted May 17, 2014 Niko, I waved to you at Japfest when you were leaving and you blanked me bro!! Chris I'm sorry I probably didn't recognise you or I'm just blind lol Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 17, 2014 Share Posted May 17, 2014 I had the same issue last week turned out to be my brake light fuse had blown! 1 Quote Link to comment Share on other sites More sharing options...
Niko Posted May 21, 2014 Author Share Posted May 21, 2014 Think I've found the problem. Notice tonight my brake lights are intermittent. So I think it's the brake pedal switch sensor. 1 Quote Link to comment Share on other sites More sharing options...
Gudzy Posted May 21, 2014 Share Posted May 21, 2014 When mine was first a problem it was possible to fix it by spraying the connections with electrical contact cleaner, might be worth a go. Quote Link to comment Share on other sites More sharing options...
Niko Posted May 21, 2014 Author Share Posted May 21, 2014 When mine was first a problem it was possible to fix it by spraying the connections with electrical contact cleaner, might be worth a go. I'll give that ago:-D Quote Link to comment Share on other sites More sharing options...
